标题: XP文件系统修复批处理 [打印本页]
作者: lgren5    时间: 2011-6-1 21:28
标题: XP文件系统修复批处理
这个批处理文件能应付系统文件被病毒篡改后相关文件修复,最好在安全模式下运行,下面代码复制到文档里,另存为.bat的文件就OK。
CLS
@ECHO OFF
COLOR 2
echo ---------------------------------------------------------------------------
echo.
echo       本程序会重新注册XP系统文件以修复系统文件
echo.
echo.
pause
cls
echo.
echo                         请耐心等待修复完成
echo.
echo.
rundll32.exe advpack.dll /DelNodeRunDLL32 %systemroot%\System32\dacui.dll
rundll32.exe advpack.dll /DelNodeRunDLL32 %systemroot%\Catroot\icatalog.mdb
regsvr32 /s setupwbv.dll
regsvr32 /s msjava.dll
regsvr32 /s wininet.dll
regsvr32 /s comcat.dll
regsvr32 /s shdoc401.dll
regsvr32 /s shdoc401.dll /i
regsvr32 /s asctrls.ocx
regsvr32 /s oleaut32.dll
regsvr32 /s shdocvw.dll /I
regsvr32 /s browseui.dll
regsvr32 /s browseui.dll /I
regsvr32 /s msrating.dll
regsvr32 /s mlang.dll
regsvr32 /s hlink.dll
regsvr32 /s mshtml.dll
regsvr32 /s mshtmled.dll
regsvr32 /s urlmon.dll
regsvr32 /s plugin.ocx
regsvr32 /s sendmail.dll
regsvr32 /s comctl32.dll /i
regsvr32 /s inetcpl.cpl /i
regsvr32 /s mshtml.dll /i
regsvr32 /s scrobj.dll
regsvr32 /s mmefxe.ocx
regsvr32 /s proctexe.ocx mshta.exe /register
regsvr32 /s corpol.dll
regsvr32 /s jscript.dll
regsvr32 /s msxml.dll
regsvr32 /s imgutil.dll
regsvr32 /s thumbvw.dll
regsvr32 /s cryptext.dll
regsvr32 /s rsabase.dll
regsvr32 /s triedit.dll
regsvr32 /s dhtmled.ocx
regsvr32 /s inseng.dll
regsvr32 /s iesetup.dll /i
regsvr32 /s hmmapi.dll
regsvr32 /s cryptdlg.dll
regsvr32 /s actxprxy.dll
regsvr32 /s dispex.dll
regsvr32 /s occache.dll
regsvr32 /s occache.dll /i
regsvr32 /s iepeers.dll
regsvr32 /s wininet.dll /i
regsvr32 /s urlmon.dll /i
regsvr32 /s digest.dll /i
regsvr32 /s cdfview.dll
regsvr32 /s webcheck.dll
regsvr32 /s mobsync.dll
regsvr32 /s pngfilt.dll
regsvr32 /s licmgr10.dll
regsvr32 /s icmfilter.dll
regsvr32 /s hhctrl.ocx
regsvr32 /s inetcfg.dll
regsvr32 /s trialoc.dll
regsvr32 /s tdc.ocx
regsvr32 /s MSR2C.DLL
regsvr32 /s msident.dll
regsvr32 /s msieftp.dll
regsvr32 /s xmsconf.ocx
regsvr32 /s ils.dll
regsvr32 /s msoeacct.dll
regsvr32 /s wab32.dll
regsvr32 /s wabimp.dll
regsvr32 /s wabfind.dll
regsvr32 /s oemiglib.dll
regsvr32 /s directdb.dll
regsvr32 /s inetcomm.dll
regsvr32 /s msoe.dll
regsvr32 /s oeimport.dll
regsvr32 /s msdxm.ocx
regsvr32 /s dxmasf.dll
regsvr32 /s laprxy.dll
regsvr32 /s l3codecx.ax
regsvr32 /s acelpdec.ax
regsvr32 /s mpg4ds32.ax
regsvr32 /s voxmsdec.ax
regsvr32 /s danim.dll
regsvr32 /s Daxctle.ocx
regsvr32 /s lmrt.dll
regsvr32 /s datime.dll
regsvr32 /s dxtrans.dll
regsvr32 /s dxtmsft.dll
regsvr32 /s vgx.dll
regsvr32 /s WEBPOST.DLL
regsvr32 /s WPWIZDLL.DLL
regsvr32 /s POSTWPP.DLL
regsvr32 /s CRSWPP.DLL
regsvr32 /s FTPWPP.DLL
regsvr32 /s FPWPP.DLL
regsvr32 /s FLUPL.OCX
regsvr32 /s wshom.ocx
regsvr32 /s wshext.dll
regsvr32 /s vbscript.dll
regsvr32 /s wupdinfo.dll
regsvr32 /s shimgvw.dll
regsvr32 /s wmpdxm.dll
regsvr32 /s appwiz.cpl
regsvr32 /s msi.dll
regsvr32 /s /i shell32.dll
regsvr32 /s scrrun.dll mstinit.exe /setup
regsvr32 /s msnsspc.dll /SspcCreateSspiReg
regsvr32 /s msapsspc.dll /SspcCreateSspiReg
cls
echo.
echo                     修复完成,建议立即重启计算机
echo.
echo.
SET /P ST=   请输入 1 (重启计算机)或 2 (关机)或 3 (直接退出)并按回车键
echo.
if /I "%ST%"=="1" goto QW
if /I "%ST%"=="2" goto QE
if /I "%ST%"=="3" goto EX
exit
W
shutdown -r -t 0
E
shutdown -s -t 0
:EX
作者: 锥处囊中    时间: 2011-6-1 21:57
这个怎么用啊  我是看不懂的LZ说说
作者: 商农    时间: 2011-6-1 21:58
没用过  不知道咋样 !!干嘛不直接建成个文件传上来!!
作者: gzacd    时间: 2011-6-1 22:08
这个是修复组件对不?
作者: 被改写的风    时间: 2011-6-1 22:32
看不懂啊!重装系统行不...
