我的电脑的显卡是 :Nvidia GeForce4 420 Go chipset
在 suse10.0下装好驱动后原来的全屏变成了显示屏右边有一列1公分的黑屏,
请问怎么解决?[/QUOTE]
在redhat9.0 和ubuntu 5.10中也同样遇到安装显卡驱动后液晶屏右面出现一列黑屏,但是可以通过这样的方法解决:
Supported well by the binary Nvidia drivers, supported by standard XFree86 nv driver since 4.3.0 (2D only) but for earlier versions you may need to use vesa driver for the initial install. My XF86Config-4 is available here
If you are having problems with there being a black border down the right side of the screen add the following lines to your /etc/modules.conf (some may already exist)
alias /dev/nvidia* nvidia
alias char-major-195 nvidia
options nvidia NVreg_SoftEDIDs=0 NVreg_Mobile=2
但是在 suse 10.0中就不行了 ,方法试了很多次,但是都失败了 ,
