标题: 求DELL 1501 BIOS [打印本页] 作者: 黄剑宁 时间: 2011-4-16 15:00 标题: 求DELL 1501 BIOS 这个笔记本上电池就报错,WARNING:The battery cannot be identified.
This system will be unable to charge this battery.
Press <F2> 2 times to enter SETUP
Press <F12> and Any Key to enter Boot Menu.
是945的桥。不上电池就没有报错。可以进系统
