标题: 求ECS给TCL代工的P4M890T-M2的BIOS [打印本页]
作者: 凯华电脑    时间: 2011-3-12 22:09
求ECS给TCL代工的P4M890T-M2 V1.0B的BIOS
作者: wenwencaixt    时间: 2011-3-12 22:36
BIOS 名称
BIOS for P4M890T-M2 (PCB:1.x)
译文
07/05/15
Release Date
2007/05/15
更新描述
-Update micro code for Conroe 4xx,E6xxx,E4xxx,E2160 series cpu
-Patch code to fix system boot fail when using some ATI PCIE card
-Update release
-Fixed S3 wake up fail with PCIE vga card on some M/B
-Support Wide Screen
-Fixed some M/B LAN device disappeared after System reboot
-Fixed System couldn't boot when using Celeron 2.66G/2.93G with some DDR1 DRAM on some M/B
记名票据
The BIOS is for South Bridge VIA® VT8237R+ only.
文件大小
1.02MB
070515.zip (1.03 MB, 下载次数: 64)
