标题: ST酷鱼常见故障大全及维修办法 [打印本页]
作者: zayh2008    时间: 2008-3-17 20:01
标题: ST酷鱼常见故障大全及维修办法
ST酷鱼常见故障大全及维修办法
(1)Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk
S.15
01-16-03 11:51
Head Mask 0000 - Switch to full int.
Spin Ready
3.06
05-13-03 14:11
(P)PATA Reset
Master
此为正常认盘信息,如果无任何报错,但扫描有坏道,可先清空SMT表,然后ERASE,若无效,则做B级工厂自校准
(2)1024k x 16 buffer detected
ALPINE - 1_Disk
M.14
01-16-03 11:51
Head Mask 000F - Switch to full int.
Spin Ready
8.01
04-05-04 15:38
(P)PATA Reset
OVERLAY FAILED(
T>
固件丢失不认盘,用快速回写原盘ATA,若无原盘固件,需找FW一样,SN号至少前4位一样的ATA,慢写
(3)(Interface task reset
ALPINE - 1_Disk
M.14
01-16-03 11:51
Spin Ready
8.01
04-05-04 15:38
(P)PATA Reset
Stuff Was Unreadable
容量参数丢失不认盘
方法:模块区,选择对应型号回写,也可自定义写参数
(4)Interface task reset
ALPINE - 1_Disk
S.15
01-16-03 11:51
Spin Ready
Failed sys sect. write
Failed sys sect. Write
Master
此类报错,先备固件,然后快速修复即可,注意:快修过程不可随意断电
(5)Interface task reset
ALPINE - 1_Disk
S.15
01-16-03 11:51
Spin Ready
AutoRd Err 43 at 700a.00.0001
AutoRd Err 47 at 700a.00.0004
AutoRd Err 43 at 700a.00.0007
AutoRd Err 47 at 700a.00.0009
Master
对于认盘前43、47报错,模块区,重复写几次容量参数,或者做工厂测试(做前要先备固件)
(6)Interface task reset
ALPINE - 1_Disk
M-21
11-25-03 18:53
Buzz
- Head Mask FFFF - Switch to full int.
Spin Ready
8.01
09-28-04 15:05
(P)PATA Reset
Master
CE Log EC=43
Rtype=24 OV=0 STStatus0
AT Er 00 Nwt Er 43 RdWr 0018.00.0000
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot:
00002c2a
ff
00002c2a.0.000 00db 0000
e700 0001
CE Log EC=47
AT Er 00 Nwt Er 47 RdWr 0018.00.0000
Niwot:
00002c2a
ff
e700 0001
对于这种认盘后报错,有固件错误和头坏,故可做B级工厂自校准或关闭磁头来修复
(7)T>Intf tsk rst 1024k x 16 buffer detected
Ref 00BE - Hd Msk 0A00 - Switch to full int.
Ready
ATRst
KEY 04h invalid in Resv!
BadRESmap!
BadDEFmap!
P
此U6盘故障,板子不对或模块错误
(8)Interface task reset
ALPINE - 1_Disk
M.14
01-Interface task reset
ALPINE - 1_Disk
M.14
01-16-03 11:51
Spin Ready
3.06
10-21-03 15:53
(P)PATA Reset
CE Log EC=0
Rtype=36 OV=0 STStatus0
Master with Non-conforming Slave
出现此信息,一般为磁头有坏,需从后往前关头,直到不出现
CE Log EC=0
为止
(9).NOT INTERFACE AGE
此信息表示该盘正在校准中,出现这个提示,查看接下来的AGE等于多少,如果不是60,则可以把该盘单独接电继续校准。
(10).AGE=60
停止校准,回写ATA.然后通病修复。断电再检测该盘,如果检测结果还是AGE=60。则重复以上操作通病修复之后不要断电,直接再启动全面校准.待校准结束后再检测。还是AGE=60的话,只有手动进入F级,选好相应的型号进行F级修复,手动进入F级具体操作参见8.8升级说明及视频。
(11)AGE=00
直接选好对应板的型号进行F级修复,如果无法引导,可以采用说明书上的手动进入F级再返回主界面做F级修复,反复引导失败.则可能是电路板损坏。考虑换板再来做F级修复。
(12)Error Reading Boot Adaptives
读取引导失败,做相应的F级修复。
(13)Error Reading Reserve Track Defect List
读取保留区缺陷列表出错,做相应的F级修复。
(14)Sweeping XXX   XXX
柱面未激活,做只读修复。做一次断一次电,反复都做不掉,可以考虑做全面自校准。
(15) Read Ver Retrys    Read Ver Failure
出现以上2个错误,可以先通病修复做几下,然后断电加点检测。如错误还是存在.则可以用只读修复,只读修复做一次断一次电,再重新装入做.直到修复掉这个错误。如果反复都失败.则考虑全面自校准。
(16) Failed  sys  sect. write
这个错误,那么可以判断这个盘是只读盘,进到程序LOAD …OK之后,点一下只读修复。等待光标出现,待修硬盘直接断电,加电、重新装入,再进行固件检测一次,如果没有只读错误,那么就算修复成功,再返回MHDD检测,如果擦除操作可以正常运行,则可以正常的分区以及写操作。只读修复光标消失5分钟左右没有出现光标。则属于只读卡死,重启之后.装入硬盘。通病修复一下之后再来做只读修复,如果只读修复卡死而且通病修复是瞬间完成的,则该盘是写磁头损坏,物理只读,只有开盘换磁头。
(17)CE Log EC=0 Rtype=XX OV=0 STStatus0
可认盘,MHDD扫描出来有不规律红绿以及坏道.固件检测有这个错误,通病修复不掉,暂时可以认为磁头即将出现问题。建议屏蔽磁头,做一次屏蔽磁头就断一次电.然后再加电检测,直到这个错误不再出现。
(18)AutoRd Err 43/47  at  XXXXXX
常说的43/47错误,固件区有坏道,认盘和不认盘都会出现这种错误,首先做通病修复,反复做几次。还是如此,可以做只读修复一次,再通病修复一次,这样做一组就断一次电,然后再来做只读+通病,反复做几轮,还是这样的话,就考虑全面自校准。校准的时候尽量不要中途断电,所以尽量先找AT电源来对待修硬盘供电。
(19)INVALID Cert Disk Code - ROM Resident Revision Required  Command Inactive - No VALID Cert Code Detected
盘板不配,读不出正确的Cert Disk Code,所以,出现INVALID(无效)的提示.出现这种提示往往是AGE=60.可以受动进到F级做F级修复或者是更换电路板
完
2007-11-18
这些都是转自效率源的资料!
[ 本帖最后由 夜雨十三天 于 2008-4-3 15:38 编辑 ]
作者: 陆波    时间: 2008-3-17 22:10
谢谢                                          看看
作者: ygss    时间: 2008-3-19 17:37
谢谢共享,下了~~~~~~~~~~~~~~~
作者: 冯小寒    时间: 2008-3-19 18:24
想下啊 ,可是是个新手,禁止我下。
作者: 大同世界    时间: 2008-3-20 23:25
谢谢 看看试试 :) :)
作者: 智之辛浩    时间: 2008-3-21 16:56
谢谢,先下载看看.........................
作者: 废烟头    时间: 2008-3-22 14:24
作者: 学修板卡    时间: 2008-3-22 16:40
请问一下楼主发的附件里的维修方法是用的什么软件的方法!
作者: 许大波    时间: 2008-3-26 15:08
顶想看看好好不好在在大看看了看看了再看看看
作者: 许大波    时间: 2008-3-26 15:09
我怎么看不了呀请楼主说说呀不让我看看我什么也看不到呀
作者: 鬼    时间: 2008-3-28 11:47
提示: 作者被禁止或删除 内容自动屏蔽
作者: 全旺    时间: 2008-3-29 08:17
下了学习一下..............
作者: 视之霸    时间: 2008-4-2 22:40
谢谢了哈,但是和其他的有点一样哈
作者: 杨高    时间: 2008-4-3 15:19
kan.........................................................................................
作者: 西门三多    时间: 2008-4-25 22:51
学是可以学的,但是没有必备工具.学了也白学1
作者: 鱼子蟹    时间: 2008-5-1 09:59
好资料啊,正需要收下了~~~~~~~~~
作者: 二江总督    时间: 2008-5-1 12:01
还没有学到这一步,先收下,留着以后慢慢学。
作者: 宏扬    时间: 2008-5-2 07:11
请问楼主如要U5开自校的文件和这个一样吗?
作者: 遥远的山    时间: 2009-1-16 00:45
很有用,谢谢分享!
否则 又要一遍一遍跑SF 了,头痛
作者: 超越电子    时间: 2009-1-16 15:07
呵呵,把春华的说明文档贴出来了
