标题: V星945GCM5 V2开机警告 [打印本页] 作者: $刀剑笑 时间: 2011-2-28 13:24 标题: V星945GCM5 V2开机警告 MS-7267(945GCM5 V2),早上接到二片这个板,一片MS-7损坏,换了OK,另一片修不出来了
故障:
不安装CMOS电池,开机后出现红色警告:Warning!!! The previous performance of overclocking is failed ,and the system is restored to the defaults setting.
安装好CMOS电池,停在V星LOGO处
