T</chmetcnv>890 Neo-V</span></font></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">故障现象:声卡(</span><span lang="EN-US"><font face="Times New Roman">ALC850</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">)不好用,量测</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的输出端,发现对地仅为</span><span lang="EN-US"><font face="Times New Roman">004</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">,判断为</span><span lang="EN-US"><font face="Times New Roman">ALC850</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">芯片短路,于是更换</span><span lang="EN-US"><font face="Times New Roman">ALC850</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">,更换后故障依旧,而且声卡温度急速升高,表面有烧黄的痕迹,量测</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的输出端,发现电压很高,为</span><span lang="EN-US"><font face="Times New Roman">10V</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">左右。更换</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">,加电测试,发现还与原来一样,这时怀疑是前个</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">损坏,导致声卡芯片同时烧坏,而后换的</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">因为声卡芯片处于短路状态,所以</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">又损坏了,于是就同时更换了</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">和</span><span lang="EN-US"><font face="Times New Roman">ALC850</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">,可是故障现象还是与原来一样,这时重新量测</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">,发现</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的调节端(</span><span lang="EN-US"><font face="Times New Roman">ADJ</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">)的电压过高。正常的应为</span><span lang="EN-US"><font face="Times New Roman">4-5V</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">左右,由于这个调节端的电压是用两个电阻分压的方法来进行产生的(图示如下:)</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">所以调节端的电压是与</span><span lang="EN-US"><font face="Times New Roman">R414</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">和</span><span lang="EN-US"><font face="Times New Roman">R415</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">这两个电阻有关的,查阅电路图后,发现</span><span lang="EN-US"><font face="Times New Roman">R414</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">为</span><span lang="EN-US"><font face="Times New Roman">100R</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的精密电阻,</span><span lang="EN-US"><font face="Times New Roman">R415</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">为</span><span lang="EN-US"><font face="Times New Roman">309R</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的精密电阻。实际量测,发现</span><span lang="EN-US"><font face="Times New Roman">R415</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的阻值</span><font face="Times New Roman">| 欢迎光临 迅维网 (https://www.chinafix.com/) | Powered by Discuz! X3.4 |
