标题: HP ATI V3100显卡花屏 [打印本页] 作者: xyq29 时间: 2010-12-8 20:59 标题: HP ATI V3100显卡花屏 显卡拿来是花屏,拿软件R3测出来结果如下
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
RV370/M22 A12b (0x5b64) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[6 ] Data mask : FAIL
Error ID G0VB006
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
failing bit : MDB0 40 41 42 43 44 45 46 47 ...
Failure detected.
我用短接法确定是第一块芯片有问题,显存位图我标出来了,如果有错的还请大家指出,软件我这传上
