标题: 双敏X550 花屏求助,五片卡一样问题显存49脚FBVTT VREF0.8V偏低不正常,好的卡是1.25V [打印本页]
作者: serveridea77    时间: 2010-11-16 09:17
显存供电2.5V正常,有六片一样的双敏X550 有的128MB 有的256MB 128BIT 拿一块测试结果上来,高手帮忙看看!用的R3测试的,根据显存定位图,mDA01-10  MDB0 1-10有问题,换了两片显存还是一样!之前是有时不显示,上BGA把核心加焊了,可以显示·花得看不清!在纯DOS下测的,用的虚似软驱!手上还有六七片,还有几片7300GT的!晕,换完显存,两片之后,测试和之前一模一样,难道BGA空焊了!请高人指教!用的板是NF6100单桥集成显卡的主板测试的!会不会不兼容啊,MV和ATI死对头!
显存图是借的别人的图,就是这种显存,正反各四片!
R3MEMID version 1.12, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
RV370/M22 A12b (0x5b63) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
    failing bit : MDA0 3 4 5 6 7 8 9 10 ... MDB0 3 4 5 6 7 8 9 10 ...
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
     error : R075A.15 not found
Failure detected.
能开机,花屏,看不清核心GPU供电1.2V,显存供电2.5V,显存49脚VREF不正常才0.8V,所有显存VREF都低,有一块好的卡,测的是1.25V,找不到从哪里来的,看ATI的图说是从VDDQ 显存供电,通过电阻分压来的,但找不到啊,只有一个电阻和49脚相连,有高人指点下吗
作者: serveridea77    时间: 2010-11-16 19:19
高人来指点下,谢谢
作者: 芯捷电脑    时间: 2010-11-16 19:41
看似所有数据位都出错,应先测GPU和显存供电。核心电压应是1.2V,显存2.6-2.7v。还要注意电容。
作者: serveridea77    时间: 2010-11-17 20:31
所有数据位出错,什么意思,我发现卡上16对电容掉了两个,补上还是一样,怎么搞!重置GPU吗
作者: serveridea77    时间: 2010-11-18 17:51
