查看: 2033|回复: 3
[显卡维修]
铭瑄x550显示字符带五颜六色
发表于 2010-10-28 18:11:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
我有一个铭瑄x550的显卡,是256的显存。此卡分了四个区。我用显卡测试软件测试后,是a通道和d通道报错。我重植后,a区好了。又是b通道报错。b16-22.我加焊了gpu后,一直报错是b16-22!!!然后,我又用软件测试后,测试结果如下:::
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDB0 40 41
[2  ] Data line toggle (GUI)                              : PASS
[3  ] RW column (GUI)                                     : PASS
[4  ] RW page (GUI)                                       : PASS
[5  ] RW channel (GUI)                                    : PASS
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDB0 16 17 18 19 20 21 22 23 ...
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : PASS
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST PASSED
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST PASSED
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST PASSED
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.15 not found
TEST RESULT SUMMARY:
R430 A11 (0x554f) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
    Error ID G0VB006
    Error ID G0VC006
    Error ID G0VC009
    Error ID G0VC018
    Error ID G0VC021
    Error ID G0VC057
    Error ID G0TR055
    Error ID G0TR014
    Error ID G0TR010
Failure detected.
请师傅们帮我分析分析是哪里的问题啊。难道 是b区有问题吗。我加焊过了!!!
我单纯的用软件测试项-----data line toggle(gui)没有问题,pass通过!!!
测试全部测试项就是上面的一连串结果!!什么问题啊!!
发表于 2010-10-28 23:02:52 | 只看该作者 �
请求版主看看啊。什么问题了!!!
发表于 2010-10-29 10:20:04 | 只看该作者 �
换掉报错的显存就应该好了
发表于 2010-10-29 11:01:37 | 只看该作者 �
这样的我也看不懂,有介绍代码的说明文章就好 了。
