七彩虹X800XL花屏
辛集腾龙电脑
2010-10-17 12:50
七彩虹X800XL花屏
七彩虹X800XL花屏 DOS下 和 自检的时候 字体乱码
检测结果:
参数:rememid -nocfg -logext
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
[1] Fill
Failing bits in test [1] Fill
errcount: 2
MDC0: 6
Failing bits in test [2] Data line toggle (GUI)
errcount: 2097024
MDC0: 6
Failing bits in test [3] RW column (GUI)
errcount: 4193282
MDC0: 2 3 4 6 7 10 11 14 15 18 19 22 23 26 27 30 31
Failing bits in test [4] RW page (GUI)
errcount: 4194178
MDC0: 2 3 6 7 10 11 14 15 18 19 22 23 26 27 30 31
Failing bits in test [5] RW channel (GUI)
errcount: 2097152
MDC0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
Failing bits in test [6] Data mask
errcount: 2097156
MDC0: 0 2 4 6 8 9 10 11 12 13 14 15 16 18 20 22 24 25 26 27 28 29 30 31
Failing bits in test [7] Macro + Micro8x2 tiling read
errcount: 710322
MDA0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
MDC0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
MDD0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
errcount: 699046
MDC0: 6
Failing bits in test [8] Macro + Micro4x4 tiling write
errcount: 699051
MDC0: 0 1 2 3 4 6 7 8 9 11 12 13 15 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
Failing bits in test [9] Byte swap macro+micro8x2 read
errcount: 4194314
MDC0: 0 1 2 3 4 5 6 8 9 10 11 12 13 14 15 16 17 19 20 23 24 25 26 28 29 30 31
Failing bits in test [10] Byte swap macro+micro4x4 write
errcount: 4194304
MDC0: 1 2 4 6 7 9 10 11 12 13 14 15 17 18 20 22 23 25 26 27 28 29 30 31
Failing bits in test [11] Marco+Micro8x2 alignment write
errcount: 10631
MDB0: 0 1 2 3 4 5 6 8 9 10 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 35 36 37 38 40 41 42 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
MDC0: 0 1 2 3 4 5 6 7 8 9 10 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 35 36 37 38 39 40 41 42 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Failing bits in test [12] Macro+Micro4x4 alignment read
errcount: 9986
MDA0: 0 1 2 3 4 5 6 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 35 36 37 38 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
MDC0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 35 36 37 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
MDD0: 0 1 2 3 4 5 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 35 36 37 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
TEST RESULT SUMMARY:
R430 A11 (0x554d) detected.
256M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : FAIL
Error ID G0VB001
1280 x 1024 - 16 bpp ( 60 Hz): TEST FAILURE
failing bit : MDC0 6
[2 ] Data line toggle (GUI) : FAIL
Error ID G0VB023
[3 ] RW column (GUI) : FAIL
Error ID G0VB024
failing bit : MDC0 2 3 4 6 7 10 11 14 ...
[4 ] RW page (GUI) : FAIL
Error ID G0VB025
failing bit : MDC0 2 3 6 7 10 11 14 15 ...
[5 ] RW channel (GUI) : FAIL
Error ID G0VB028
failing bit : MDC0 0 1 2 3 4 5 6 7 ...
[6 ] Data mask : FAIL
Error ID G0VB006
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
failing bit : MDC0 0 2 4 6 8 9 10 11 ...
[7 ] Macro + Micro8x2 tiling read : FAIL
Error ID G0VC006
failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ... MDC0 0 1 2 3 4 5 6 7 ... MDD0 0
[8 ] Macro + Micro4x4 tiling write : FAIL
Error ID G0VC009
failing bit : MDC0 0 1 2 3 4 6 7 8 ...
[9 ] Byte swap macro+micro8x2 read : FAIL
Error ID G0VC018
failing bit : MDC0 0 1 2 3 4 5 6 8 ...
[10 ] Byte swap macro+micro4x4 write : FAIL
Error ID G0VC021
failing bit : MDC0 1 2 4 6 7 9 10 11 ...
[11 ] Marco+Micro8x2 alignment write : FAIL
Error ID G0VC052
failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 8 ... MDC0 0 1 2 3 4 5 6 7 ... MDD0 0
[12 ] Macro+Micro4x4 alignment read : FAIL
Error ID G0VC057
failing bit : MDA0 0 1 2 3 4 5 6 8 ... MDB0 0 1 2 3 4 5 6 7 ... MDC0 0 1 2 3 4 5 6 7 ... MDD0 0
[13 ] Movblit, 4 align, T : FAIL
Error ID G0TR055
1024 x 768 - 16 bpp ( 75 Hz): TEST FAILURE
error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L : FAIL
Error ID G0TR014
640 x 480 - 8 bpp ( 75 Hz): TEST FAILURE
error : R051A.14 not found
640 x 480 - 15 bpp ( 75 Hz): TEST FAILURE
error : R052A.14 not found
640 x 480 - 16 bpp ( 75 Hz): TEST FAILURE
error : R053A.14 not found
640 x 480 - 32 bpp ( 75 Hz): TEST FAILURE
error : R055A.14 not found
800 x 600 - 8 bpp ( 75 Hz): TEST FAILURE
error : R061A.14 not found
800 x 600 - 15 bpp ( 75 Hz): TEST FAILURE
error : R062A.14 not found
800 x 600 - 16 bpp ( 75 Hz): TEST FAILURE
error : R063A.14 not found
800 x 600 - 32 bpp ( 75 Hz): TEST FAILURE
error : R065A.14 not found
1024 x 768 - 8 bpp ( 75 Hz): TEST FAILURE
error : R071A.14 not found
1024 x 768 - 15 bpp ( 75 Hz): TEST FAILURE
error : R072A.14 not found
error : R073A.14 not found
1024 x 768 - 32 bpp ( 75 Hz): TEST FAILURE
error : R075A.14 not found
Failure detected.
双256 BGA 1代显存
求指点
测量C区显存 背面一10欧排阻中的一个 阻值为50多 在内存上找了个 10欧排阻换上 OK 了
辛集腾龙电脑
2010-10-18 10:54
搞定了
我编辑成以解决了 不知 版主给加分不
中恒电脑
2010-10-26 12:27
一个排阻坏就出现这么多报错?
