标题: D610 怪问题 大师们看看 [打印本页] 作者: 顺溜 时间: 2010-9-17 10:07 标题: D610 怪问题 大师们看看 ****manufacturing mode:level[67]****
press fn-x to return the system to normal running mode.
这之后无任何反应,按任何键都没反应,大约过了1分钟,屏幕继续出现提示:
warning!battery is critically low.
hit f1 to continue.
之后我按下F1,出现以下字样:
the computer is docked and only battery power is detected.this can happen if zhe power adapter is missing,the power cord is unplugged,or the computer is not properly connected to the docking station.
you should undock,redock,attach a power adapter,or plug in the power cord.
