型号 | 主频 | TB加速 | 三级缓存 | 核心/线程 | 集显频率/加速 | TDP |
Core i7-2600K | 3.4GHz | 3.8GHz | 8MB | 4/8 | 850 / 1350MHz | 95W |
Core i7-2600 | 3.4GHz | 3.8GHz | 8MB | 4/8 | 850 / 1350MHz | 95W |
Core i5-2500K | 3.3GHz | 3.7GHz | 6MB | 4/4 | 850 / 1100MHz | 95W |
Core i5-2500 | 3.3GHz | 3.7GHz | 6MB | 4/4 | 850 / 1100MHz | 95W |
Core i5-2400 | 3.1GHz | 3.4GHz | 6MB | 4/4 | 850 / 1100MHz | 95W |
Core i3-2120 | 3.3GHz | N/A | 3MB | 2/4 | 850 / 1100MHz | 65W |
Core i3-2100 | 3.1GHz | N/A | 3MB | 2/4 | 850 / 1100MHz | 65W |
Core i7-2600S | 2.8GHz | 3.8GHz | 8MB | 4/8 | 850 / 1100MHz | 65W |
Core i5-2500S | 2.7GHz | 3.7GHz | 6MB | 4/4 | 850 / 1100MHz | 65W |
Core i5-2400S | 2.5GHz | 3.3GHz | 6MB | 4/4 | 850 / 1100MHz | 65W |
Core i5-2500T | 2.3GHz | 3.3GHz | 6MB | 4/4 | 650 / 1250MHz | 45W |
Core i5-2390T | 2.7GHz | 3.5GHz | 3MB | 2/4 | 650 / 1100MHz | 35W |
Core i3-2100T | 2.5GHz | N/A | 3MB | 2/4 | 650 / 1100MHz | 35W |
终于搞清楚了 非常感谢 很有帮助 可以这样理解吗 I3的都是3M缓存 双核4线程(逻辑4核?) I5的都是6M缓存 4核4线程 I7都是8M缓存 4核8线程?
