R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
[1] Fill
Failing bits in test [1] Fill
errcount: 2
MDA0: 12
Failing bits in test [2] Data line toggle (GUI)
errcount: 150075
MDA0: 12
MDB0: 60
Failing bits in test [3] RW column (GUI)
errcount: 1764
MDA0: 12
Failing bits in test [4] RW page (GUI)
errcount: 117124
MDA0: 12
MDB0: 60
Failing bits in test [5] RW channel (GUI)
errcount: 6157
MDA0: 12
MDB0: 60
Failing bits in test [6] Data mask
errcount: 1895976
MDA0: 12
MDB0: 60
Failing bits in test [7] Macro + Micro8x2 tiling read
errcount: 165876
MDA0: 12
Failing bits in test [8] Macro + Micro4x4 tiling write
errcount: 214808
MDA0: 12
Failing bits in test [9] Byte swap macro+micro8x2 read
errcount: 2640809
MDA0: 12
MDB0: 60
Failing bits in test [10] Byte swap macro+micro4x4 write
errcount: 3212632
MDA0: 12
MDB0: 60
Failing bits in test [11] Marco+Micro8x2 alignment write
errcount: 972
MDA0: 12
Failing bits in test [12] Macro+Micro4x4 alignment read
errcount: 1797
MDA0: 12
TEST RESULT SUMMARY:
RV370/M22 A12b (0x5b63) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : FAIL
Error ID G0VB001
1024 x 768 - 16 bpp ( 60 Hz): TEST FAILURE
failing bit : MDA0 12
[2 ] Data line toggle (GUI) : FAIL
Error ID G0VB023
failing bit : MDA0 12 MDB0 60
[3 ] RW column (GUI) : FAIL
Error ID G0VB024
[4 ] RW page (GUI) : FAIL
Error ID G0VB025
[5 ] RW channel (GUI) : FAIL
Error ID G0VB028
[6 ] Data mask : FAIL
Error ID G0VB006
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
[7 ] Macro + Micro8x2 tiling read : FAIL
Error ID G0VC006
[8 ] Macro + Micro4x4 tiling write : FAIL
Error ID G0VC009
[9 ] Byte swap macro+micro8x2 read : FAIL
Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write : FAIL
Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write : FAIL
Error ID G0VC052
[12 ] Macro+Micro4x4 alignment read : FAIL
Error ID G0VC057
[13 ] Movblit, 4 align, T : FAIL
Error ID G0TR055
1024 x 768 - 16 bpp ( 75 Hz): TEST FAILURE
error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L : FAIL
Error ID G0TR014
640 x 480 - 8 bpp ( 75 Hz): TEST FAILURE
error : R051A.14 not found
640 x 480 - 15 bpp ( 75 Hz): TEST FAILURE
error : R052A.14 not found
640 x 480 - 16 bpp ( 75 Hz): TEST FAILURE
error : R053A.14 not found
640 x 480 - 32 bpp ( 75 Hz): TEST FAILURE
error : R055A.14 not found
800 x 600 - 8 bpp ( 75 Hz): TEST FAILURE
error : R061A.14 not found
800 x 600 - 15 bpp ( 75 Hz): TEST FAILURE
error : R062A.14 not found
800 x 600 - 16 bpp ( 75 Hz): TEST FAILURE
error : R063A.14 not found
800 x 600 - 32 bpp ( 75 Hz): TEST FAILURE
error : R065A.14 not found
1024 x 768 - 8 bpp ( 75 Hz): TEST FAILURE
error : R071A.14 not found
1024 x 768 - 15 bpp ( 75 Hz): TEST FAILURE
error : R072A.14 not found
error : R073A.14 not found
1024 x 768 - 32 bpp ( 75 Hz): TEST FAILURE
error : R075A.14 not found
[15 ] Line slopes/dir/P/solid : FAIL
Error ID G0TR010
error : R051A.15 not found
error : R052A.15 not found
error : R053A.15 not found
error : R055A.15 not found
error : R061A.15 not found
error : R062A.15 not found
error : R063A.15 not found
error : R065A.15 not found
error : R071A.15 not found
error : R072A.15 not found
error : R073A.15 not found
error : R075A.15 not found
Failure detected.
