查看: 2624|回复: 6
[显卡维修]
X800小花,有测试结果!!!
发表于 2010-8-16 08:34:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
有快X800的显卡,进XP画面的时侯有点小花,R3113的测试结果,请大家帮忙分析分析!!!
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
R430 A11 (0x554f) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDB0 24
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ... MDC0 0 1 2 3 4 5 6 7 ... MDD0 0
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
    failing bit : MDA0 0 1 2 3 4 5 7 8 ... MDB0 0 1 2 3 4 5 8 9 ... MDC0 0 1 2 3 4 5 6 7 ... MDD0 0
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST PASSED
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST PASSED
   800 x  600 -  8 bpp ( 75 Hz): TEST PASSED
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST PASSED
  1024 x  768 -  8 bpp ( 75 Hz): TEST PASSED
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST PASSED
Failure detected.
发表于 2010-8-16 09:44:50 | 只看该作者 �
就是,BGA好了。
发表于 2010-8-16 11:45:13 | 只看该作者 �
显卡花屏要看什么情况的花屏
1,字体异常,80%是显存的问题,加焊大部分能好
2,竖线状的花屏,大部分通过加焊GPU基本可以搞定
3,满屏花的情况,先看看是否有滤波电容鼓包漏液,如果有滤波电容鼓包漏液,70%的情况下都能够更换电容搞定,如果电容无明显的外观问题,应该采取先测试后加焊的原则,如果没有测试软件或者测试软件不支持,应该依照先加显存再加GPU的原则,
4,显卡bios导致花屏的情况数量不多,所以先将掉件,电容鼓包,显存和显卡芯片排除掉之后在进行BIOS程序刷新
最后加焊过程中使用的焊宝最好使用专用的GBA焊宝,提高成功率,焊宝不宜添加过多,过多会再加热的时候产生气泡,影响焊接质量
发表于 2010-8-16 20:15:10 | 只看该作者 �
B通道24 脚位出错,查上下拉排阻
发表于 2010-8-16 20:23:57 | 只看该作者 �
为什么后面通道都报错了?
发表于 2010-8-17 21:16:43 | 只看该作者 �
软件版本不对,就会出现这种情况的
发表于 2010-9-7 10:23:48 | 只看该作者 �
检查排阻,测下AD线的对地阻值
