标题: 9800se花屏,请指点一下 [打印本页]
作者: 圣达    时间: 2010-8-10 17:39
标题: 9800se花屏,请指点一下
今天收到一块9800se,花屏。第一次尝试修显卡,下了r3,测试结果如下,请帮忙分析一下该从哪里下手,已经加焊正反8个显存,显存周边的排阻也检测过了正常。该从哪里下手呢?
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDC0 34 56 57 58 59 60 61 62 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
    failing bit : MDC0 0 1 2 3 4 5 6 7 ... MDD0 0 1 2 3 4 5 6 7 ...
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
    failing bit : MDC0 3 4 5 6 7 8 9 10 ... MDD0 3 4 5 6 8 9 10 11 ...
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
    failing bit : MDC0 3 4 5 7 8 9 10 11 ... MDD0 3 4 5 6 7 8 9 10 ...
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
     error : R075A.15 not found
TEST RESULT SUMMARY:
R350 (0x4148) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
    Error ID G0VB023
    Error ID G0VB024
    Error ID G0VB025
    Error ID G0VB028
    Error ID G0VB006
    Error ID G0VC006
    Error ID G0VC009
    Error ID G0VC018
    Error ID G0VC021
    Error ID G0VC052
    Error ID G0VC057
    Error ID G0TR055
    Error ID G0TR014
    Error ID G0TR010
Failure detected.
作者: 凌寒    时间: 2010-8-10 23:01
一代的显存容易坏先把左边后面的那个换了先再测
作者: 乐天    时间: 2010-8-10 23:43
核心空焊的可能性最大
作者: moyam1220    时间: 2010-8-11 00:44
住芯片  坏了  和颗粒无关
作者: huangyansong    时间: 2010-8-11 01:28
核心从做.如果还不好的话,就好核心挂了
作者: 潘卓斌    时间: 2010-8-11 12:48
这样花的我一般不修了 不是显存坏就是GPU要换、重值.....
作者: 圣达    时间: 2010-8-11 20:10
今天试了加焊GPU,花屏更加严重了。这两天忙,等抽空再搞搞它,不行就当料板了。谢谢各位帮忙指点!!
作者: j任我行    时间: 2010-8-18 09:11
GPU 虚焊 80%
