标题: ATI RADEON 9600 花屏测试结果,高手解决 [打印本页]
作者: zhangliu7527    时间: 2010-8-5 22:00
花屏,请各位帮忙看看结果,是哪的问题
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
Rv350 (0x4151) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.8 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.8 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.8 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.8 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.8 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.8 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.8 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.8 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.8 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.8 not found
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.8 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.8 not found
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
     error : R051A.9 not found
     error : R052A.9 not found
     error : R053A.9 not found
     error : R055A.9 not found
     error : R061A.9 not found
     error : R062A.9 not found
     error : R063A.9 not found
     error : R065A.9 not found
     error : R071A.9 not found
     error : R072A.9 not found
     error : R073A.9 not found
     error : R075A.9 not found
Failure detected.
存显和GPU位置为:
                      U34/U30(后面)
         GPU       U33 /U29(后面)
作者: 凌寒    时间: 2010-8-5 22:20
A区报错因为A卡的测试软件只能显示8个的错位后面...表示后面还 有,你先把左边后A面最低下那个显存换了再测。
作者: zhangliu7527    时间: 2010-8-5 22:41
回复 凌寒 的帖子
如果按位置图的话应该是哪个呢,就四个显存
作者: 凌寒    时间: 2010-8-6 10:31
右边最底下那个
作者: 乐天    时间: 2010-8-7 19:34
最下面的那个不一定是坏的,你可以查一下背反最下两颗的相关引脚对地阻抗
切记,显存电压也不能有偏值
作者: 显卡修好了    时间: 2010-8-7 23:14
显存供电是否正常?
核心晶圆是否完好?
显存公用线对地压降值是否异常?
一切ok  更换首位显存,试下在测试!
作者: 周明坤    时间: 2010-8-7 23:23
显存供电及显存外围排阻不容忽视
