今天刚到手的 FLUKE105B 100M示波表 拆开看了下
dreamzzg
2010-8-3 14:40
感觉不质哪么多钱
dreamzzg
2010-8-3 14:42
感觉不质哪么多钱
Fluke 105B 100 MHz ScopeMeter Series II
Fluke 105B Features:
■High-Contrast, Backlit Display
■Automatic Setup Measurements: 40
■Waveform and Screen image transfers to a PC and Remote Operation
■Screen Image Transfers to a PC
■Signal Generator/Component Tester Output
■On-line Help (information)
■4 Hour NiCad Battery and Charger
■Optically Isolated RS-232C Interface for Printer and PC (PM 9080 cable required)
■PC Software & PM 9080 Cable
■Hard Carrying Case
Multimeter Features:
■5 MHz DMM Measurements & Full Waveform
■Autoranging
■Min Max TrendPlot with New Time and Date Stamp
■Advanced Measurements: Temp., Current, RPM, % Duty, Pulse Width, dB, Hz, % Scale, Amps, Watts, and more
■True-rms Volts
■Diode Test (up to 2.8V)
■Continuity Beeper
Oscilloscope Features:
■Bandwidth: 100 MHz
■Maximum Repetitive Sample Rate: 5 GS/s
■Maximum Time Resolution: 200 ps
■Number of Channels: 2
■Continuous Autoset
■Video Triggering, NTSC, PAL. SECAM, & Hi Resolution Video (l& field selectable)
■ScopeRecord
? in 30k Memory; (Time base ≥20 ms/div)
■Glitch Capture down to 40 ns
■Time/Division: 5 ns/div to 60 sec/div
■Volts/Division: 1 mV/div to 100 V/div
■Pre & Post Trigger: -20 to +640 div
■Trigger Delay: Cycles, Event, Time & Zoom
■Envelope Mode: Min/Max
■Gray Scale Waveform Display
■Cursor Measurements
■Waveform Mathematics: Integrate, +, -, filter
■Measure Amps with Optional Current Clamps
■Screen Memory: 10
■Waveform Memory: 20
■Setup Memory: 40
学则不固
2010-8-3 14:42
LZ上个图看一下。
dreamzzg
2010-8-3 14:46
回复
dreamzzg
的帖子
风之源
2010-8-3 14:52
回复
dreamzzg
的帖子
我看到你的淘宝上而的成交价是3800块啊。。。多少钱入手,怎么要这么贵?
龚成贵
2010-8-3 22:07
我有台THS730A的是200M的
瑞辉电脑
2010-8-3 22:58
怎么也好不过一台示波器,如果示波表能比得上示波器的话,示波器就不用做的体积那么大了,就不会有人买示波器了。
陈祖平
2010-8-3 23:27
回复
瑞辉电脑
的帖子
楼上说的太对了,3800,太贵了
龚成贵
2010-8-4 08:53
示波表是方便但是价格太贵
罗嘉成
2010-8-4 16:19
示波表不是不行,它的性能超群,比如FLUKE199B,泰克THS720,730等等,只是太贵,买来维修,成本太高.一般都是实验室搞研发的.还有一种电路板在线测试仪, 用在维修上,非常好,但是几十万的价格,谁会用在维修上呢?买工具也是要有运气的.
刀鱼在线
2010-8-4 17:34
如想出手 可以 联系我的
龚成贵
2010-8-4 17:42
回复
刀鱼在线
的帖子
我的THS730A想转出去,哈哈
刀鱼在线
2010-8-4 18:03
回复
龚成贵
的帖子
我是拿 青龙偃月刀 来的 , PM下 你的价格
龚成贵
2010-8-4 18:31
5500出给 你我自己是还有个屏坏的99B
