标题: VFAN CONTROL IDEA COMPAQ V3000 [打印本页] 作者: 9notebook 时间: 2010-8-1 22:16 标题: VFAN CONTROL IDEA COMPAQ V3000 i get idea from here thank you for good knowledge thank you very much.If i have wrong can advice and tell me.
today i read laptop discussion about fan voltage control,sorry i forget link topic.
Compaq V3000 SHIBA model gpu heat-cycle fail.I chang a new gpu 6150.OK it's work and then i try to modify my fan voltage.I want to adjust VFAN for 3.3 volt when start and when it's hot just rise up to 5v becouse if i use only 5v all time it's noisy and loud.that can see photo below.That's ok.Thanks for Chinafix about good idea,thanks again.
***i don't know how to upload photo.I try and fail.***
