标题: TOSHIBA M200 Miami-10 fix [打印本页] 作者: 9notebook 时间: 2010-7-28 17:45 标题: TOSHIBA M200 Miami-10 fix sorry to use english. Toshiba m200 screen problem when use adaptor plugin.i will share my picture that can solve problem.
1. add 2 capacitor to Vcore-line don't remove NEC/TOKIN 128 it's work well.
[attach]184772[/attach][attach]184774[/attach]
2. remove NEC/TOKIN 128 and add 330 uf x 4 capacitor it's OK but use more time.
.[attach]184776[/attach][attach]184778[/attach]
thanks you. 作者: 9notebook 时间: 2010-7-28 19:05
