标题: toshiba m205 [打印本页] 作者: 专业人 时间: 2010-7-28 02:46 标题: toshiba m205 hello,
i have toshiba sat m205 invetec board when using charger and batt the laptop hangs.if you use only adapter then works in windows no problem orif you use only battery then works ok.but when use charger ad battery the hags in windows.i have 2 pcs with same problem.
thanks for help 作者: 梧桐叶 时间: 2010-7-28 09:43
adapter detect or exchange problems作者: 墨星 时间: 2010-7-28 09:44
The attempt replaces the cpu electric capacity
