查看: 2932|回复: 9
[显卡维修]
x550显卡求救
发表于 2010-7-27 23:02:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 浙江温州 来自 浙江温州
我这几天接了一个网吧送来30张X550显卡,有的花,有的不显,用R3112检测好的卡如下
R3MEMID version 1.12, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
RV370/M22 A13 (0x5b63) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : PASS
[12 ] Macro+Micro4x4 alignment read                       : PASS
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
     error : R075A.15 not found
Failure detected.
花屏的检测如下,测试了好几块都如下面的,搞不懂,如果是显存,不可能都一样啊,
128M video memory.
[1  ] Fill                                                : FAIL
    Error ID G0VB001
    Error ID G0VB023
    Error ID G0VB024
    Error ID G0VB025
    Error ID G0VB028
    Error ID G0VB006
    Error ID G0VC006
    Error ID G0VC009
    Error ID G0VC018
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
    failing bit : MDB0 4
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
    Error ID G0TR055
    Error ID G0TR014
    Error ID G0TR010
Failure detected.
发表于 2010-7-27 23:03:35 | 只看该作者 来自: 湖南怀化 来自 湖南怀化
什么也不懂得小白帮顶
发表于 2010-7-27 23:06:24 | 只看该作者 来自: 福建厦门 来自 福建厦门
全是洋码子
发表于 2010-7-27 23:06:32 | 只看该作者 来自: 浙江温州 来自 浙江温州
用R5,R6,R3107,都不能测试,就是不知道是不是要R3113的版本,但是网上找了好久都没有,那位朋友有的话帮忙发一个,谢谢了,279128149@qq.com
发表于 2010-7-27 23:15:56 | 只看该作者 来自: 辽宁沈阳 来自 辽宁沈阳
这个需要R31.13版本的,软件集合贴就有下载
发表于 2010-7-27 23:19:45 | 只看该作者 来自: 辽宁沈阳 来自 辽宁沈阳
发表于 2010-7-27 23:49:13 | 只看该作者 来自: 浙江温州 来自 浙江温州
阅读权限: 40 下不了,别的那里还有吗,我用基地维修工具盘也没有。
发表于 2010-7-28 15:49:56 | 只看该作者 来自: 山东淄博 来自 山东淄博
  可能软件 出错了
看一下你的测试结果     这卡估计的话大价钱
发表于 2010-7-28 16:39:01 | 只看该作者 来自: 广东东莞 来自 广东东莞
没有人介绍一下使用方法吗?不是很会分析结果啊
发表于 2010-7-28 22:11:06 | 只看该作者 来自: 辽宁沈阳 来自 辽宁沈阳
不会分析方法的会员可以先仔细搜索贴子,要学会利用论支的搜索功能,找到相关贴有不懂的再提问,不然不知道从哪给你们讲起
