作者: 深度电脑电器 时间: 2010-7-5 08:06
电容从外观上看是很正常,把滤波电容取下来也是一样2.49V到2.5V在变,我怀疑是那个转换电压的稳压管问题,但没有那管子换!作者: 凝海 时间: 2010-7-5 08:09
内存供电有跳动,那内存工作在一个不稳定的状态下,会出现蓝屏现像的。先把这个故障修好作者: 太行电脑医院 时间: 2010-7-5 08:27
看来你的主板需要先修好内存供电部分才能进一步修作者: skyeagles 时间: 2010-7-5 08:39
2.49-2.5V也算是跳变?作者: 深度电脑电器 时间: 2010-7-5 09:02
全新安装时提示的蓝屏信息如下:
A problem has been detected and windows has been shut down to prevent damage to your computer
If this is the first time you've seen this stop error screen restart your computer.If this screen appears again,follow these steps:
The BIOS in this system is not fully ACPI compliant.please contact your system vendor or visit http://www.hardware-update.com for an updated BIOS. If you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant,you can turn off ACPI mode during text mode setup.to do this ,simply press the F7 key when you are prompted to install storage drivers.The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation.
*** STOP: 0x000000A5 (0x00010003 , 0x85E37CD0 , 0X0000000B , 0x85E885E4)
The ACPI BIOS in this system is not fully compliant with the ACPI specification.please read the README.TXT for possible workarounds you can also contact your system's mamufacturer for an update BIOS,or vist http://www.hardware-update.com to see if a new BIOS is aviailable.
The BIOS in this system is not fully ACPI compliant.please comtact your system vendor or visit http://www.hardware-update.com for an updated BIOS if you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant,you can turn off ACPI mode durring text mode setup.to do this,simple press the F7 key when you are prompted to install storage drivers.the system will not notify you that the F7 key was pressed.it will silently disable ACPI and allow you to continue your installation.
来源:(http://blog.sina.com.cn/s/blog_47c0b7f601008s27.html) - 系统统蓝屏并提示BIOS ACPI有问题,代码:0x000000A5_月生禾刀_新浪博客
0x000000A5:ACPI_BIOS_ERROR
错误分析:通常是因为主板BIOS不能全面支持ACPI规范.
解决方案:如果没有相应BIOS升级, 那么可在安装Windows 2000/XP/时, 当出现"press F6 if you need to install a third-party SCSI or RAID driver"提示时, 按下F7键, 这样Windows便会自动禁止安装ACPI HAL, 而安装 Standard PC HAL。
