数据总线由于持续处于高负载下相对于地址总线来讲对调整更加的敏感。那些希望实验的狂热玩家最好能在作其他改动前先改动数据总线的GTL ref。图二显示了与GTL ref相关的修改点-电位器可以轨到轨(0.4v到1.2v)的设置GTL ref电压。主板/芯片组初始GTL ref电压应该是2/3 VTT(大约是0.8v),虽然你可能会测量出在你的主板上这个值要低一点(接近0.75v)作者: hbyq 时间: 2010-5-24 21:39
its about the minimum voltage to count as 'on' and the maximum voltage to count as 'off' in the signal, obviously if you put it too high or low you'll mess it up
