求助,max1809
孤忆心欣
2010-5-16 08:51
求助,max1809
这个芯片是不是用于内存供电,可以用什么芯片代换啊
吴正海
2010-5-16 09:03
参数名 参数值
Topology Step-Down
Vin min V 3
Vin max V 5.5
DC-DC Outputs num. of 1
Preset Vout V -
Digital/ VID Prog. Out. No
Adj. Vout min V 1.1
Adj. Vout max V 5.5
Iout A 3
Icc max mA 1
Fxd. Freq./ PWM Oper. Yes
Oper. Freq. kHz 1000
Internal Pwr. Switches Yes
Sync. Rectifier Yes
Features Adjustable Frequency, Shutdown, Soft Start, Current limit
Industry Qualified -
Package/Pins QSOP/16, THIN QFN/28, THIN QFN/32, QFN/28
Smallest Available Package max w/pins mm2 26
梧桐叶
2010-5-16 11:21
www.icpdf.com
自己去看
