查看: 3356|回复: 3
dv4 la-4111p
发表于 2010-5-7 03:12:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
hello anyone have board viewer for dv4 amd la4111p .does not power up the acoff signal looks shorted
thanks
发表于 2010-5-7 11:41:15 | 只看该作者 �
发表于 2010-5-8 04:16:07 | 只看该作者 �
downloadthe file la4111p but try to view it on boardviewer r4 does not show anything when load file .any idea what the problem is.
thanks
发表于 2010-5-8 17:34:34 | 只看该作者 �
The kind of these big size  boardview with "BRD" extension must use a special boardview software.
