标题: 华硕A6T不通电 [打印本页]
作者: zhangmaoming    时间: 2010-4-19 17:02
标题: 华硕A6T不通电
插上电源待机电压0.06V,开关上的电压0.8翻 [fān]
    cross   search   translate   turn over
动词 1.(变换位置; 歪倒; 反转) turn over; turn around; reverse 2.(移动物体寻找) rummage; search 3.(推翻原来的) reverse; retract; withdraw 4.(爬过; 越过) climb over; get over; cross 5.(成倍地增加) multiply 6.(翻译) translate 7.[口] (翻脸) break up; fall out
V .
