SATA引脚定义
张先生
2007-10-8 17:49
SATA引脚定义
(9.65 KB, 下载次数: 81)
下载附件
保存到相册
2007-10-8 17:49 上传
SATA Data pinout
SATA PinOut, Data Pin # Signal Name Signal Description
1 GND Ground
2 A+ Transmit +
3 A- Transmit -
4 GND Ground
5 B- Receive -
6 B+ Receive +
7 GND Ground
SATA Power pinout
SATA PinOut, Power Pin # Signal Name Signal Description
1 V33 3.3v Power
2 V33 3.3v Power
3 V33 3.3v Power, Pre-charge, 2nd mate
4 Ground 1st Mate
5 Ground 2nd Mate
6 Ground 3rd Mate
7 V5 5v Power, pre-charge, 2nd mate
8 V5 5v Power
9 V5 5v Power
10 Ground 2nd Mate
11 Reserved -
12 Ground 1st Mate
13 V12 12v Power, Pre-charge, 2nd mate
14 V12 12v Power
15 V12 12v Power
PATA Power pinout
IDE Power Connector Pin Out Pin # Signal Function 18 AWG Wire
1 +12V DC Yellow
2 +12V Return Black
3 +5V Return Black
4 +5V DC Red
