6500GT 128M 128B 花屏维修
a344796658
2010-4-15 23:15
6500GT 双128 ,
正面, 反面
U1 U5
U2 U6
GPU GPU
U3 U7
U4 U8
测试结果如下
Tested from 0 MB to 64 MB.
LANE E_BANK0 ERRORS EBANK_1 ERRORS
FBA[31: 0] 8459008 8477952
FBA[63:32] 7 8469818
External Bank 0 Failing bits:
A03 A34 A35 A49 A50 A51
External Bank 1 Failing bits:
A03 A43
Read Error Count: 4576539
Write Error Count: 20830246
Unknown Error Count: 0
已判断A03 是U6
短接了U6 1 2 脚
换了U6 U3 后
测试结果如下,
FBA[31: 0] 0 0
FBA[63:32] 0 8469818
A41 A43
Read Error Count: 0
Write Error Count: 8469818
换掉U6后正常
共坏3片显存, U3 U4 U6
