标题: 跑D0 [打印本页] 作者: 赵锋 时间: 2007-10-5 18:04 标题: 跑D0 我有两块一样的杂牌主板,都是跑D0,CPU和内存.显卡电压都正常,是不是该刷BIOS啊?作者: bjall 时间: 2007-10-5 18:14
有可能是座子虚焊,用手压住测测作者: 张先生 时间: 2007-10-5 18:15
Phoenix bios:
D0-D2
If an interrupt occurs before interrupt vectors have been initialised this interrupt handler will try to see if the interrupt caused was an 8259 interrupt and which one. If the interrupt is unknown, InterruptFlag will be FF. Otherwise it will contain the IRQ number that occurred
