今天接到一台DELL D610 ,可以开机,但是用电池的时候有时进不了系统,进不了系统的时候出来一段英语,如下:the computer is docked and only battery power is detected. this can happen if the power adapter is missing,the power cord is unplugged,or the computer is not properly connected to the docking station.
you should undock,redock,attach a power adapter,or plug in the power cord.
最后还有一段,好像是按F1就关机了什么的。
因为是进过水的机器,从电源头到开关板那一段都有水痕,已经清理过。
