ZXCVWtest
麻烦大家帮忙分析下测试结果,9550 128M的卡
wbin0611
2010-3-20 11:47
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...Failing bits in test [1] Fill
errcount: 12641213
MDA0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [1] Fill
errcount: 12961776
MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [2] Data line toggle (GUI)
errcount: 6157716
MDA0: 16 17 18 19 20 21 22 23
MDB0: 20 21 48 49 50 51 52 53 54 55Failing bits in test [3] RW page (GUI)
errcount: 16458022
MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [4] RW channel (GUI)
errcount: 9447887
MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [5] Data mask
errcount: 10501496
MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [6] Macro + Micro8x2 tiling read
errcount: 3395414
errcount: 3390693
MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [7] Byte swap macro+micro8x2 read
errcount: 25773289
MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [8] HOST_DATA/<f,b>/M2L
errcount: 2472
MDA0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23 49 50 52 53 55
MDB0: 17 18 19 20 21 22 23 48 49 50 51 52 53 54 55Failing bits in test [8] HOST_DATA/<f,b>/M2L
errcount: 8706
MDA0: 16 17 18 19 20 21 22 23 50 52 55
MDB0: 16 17 18 19 20 21 22 23 48 49 50 51 52 53 54 55Failing bits in test [8] HOST_DATA/<f,b>/M2L
errcount: 9398
MDA0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
errcount: 15845
MDA0: 16 17 18 19 20 21 22 23 49 50 51 52 55
errcount: 7608
MDA0: 16 17 18 19 20 21 22 23 48 49 50 51 52 53 54 55
errcount: 13238
MDA0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 48 49 50 51 52 53 54 55
MDB0: 17 18 20 21 22 23 48 49 50 51 52 53 54 55Failing bits in test [8] HOST_DATA/<f,b>/M2L
errcount: 15163
errcount: 23489
errcount: 13818
MDA0: 0 1 2 3 4 5 6 7 16 17 18 19 20 21 22 23 49 50 51 52 53 54 55
errcount: 22535
MDA0: 0 1 2 3 4 5 6 7 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 50 52 55
MDB0: 18 20 21 22 23 49 50 51 52 53 54 55Failing bits in test [8] HOST_DATA/<f,b>/M2L
errcount: 27377
errcount: 53156
MDA0: 1 2 3 4 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 33 34 35 36 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
MDB0: 1 2 3 4 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 33 34 35 36 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55Failing bits in test [9] Line slopes/dir/P/solid
errcount: 2260
MDA0: 16 17 18 19 20 21 22 23 49 50 52 53 54 55 56 58 59 60 61 62 63
MDB0: 17 18 20 21 22 23 48 49 50 51 52 53 54 55Failing bits in test [9] Line slopes/dir/P/solid
errcount: 6445
MDA0: 16 17 18 19 20 21 22 23 56 57 58 59 60 61 62 63
MDB0: 16 17 18 19 20 21 22 23 48 49 50 51 52 53 54 55Failing bits in test [9] Line slopes/dir/P/solid
errcount: 7209
errcount: 9284
MDA0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 48 49 50 51 52 53 54 55
errcount: 5136
errcount: 8743
MDA0: 16 17 18 19 20 21 22 23 50 52 55 56 57 58 59 60 61 62 63
errcount: 8781
errcount: 12242
errcount: 9196
MDA0: 16 17 18 19 20 21 22 23 48 49 50 51 52 53 54 55 56 58 59 60 61 62 63
errcount: 9985
errcount: 393216
MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63Failing bits in test [9] Line slopes/dir/P/solid
errcount: 786432
TEST RESULT SUMMARY:
wbin0611
2010-3-20 11:48
Rv350 (0x4153) detected.
256M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : FAIL
Error ID 0VB001
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[2 ] Data line toggle (GUI) : FAIL
Error ID 0VB023
failing bit : MDA0 16 17 18 19 20 21 22 23 MDB0 20 21 48 49 50 51 52 53 ...
[3 ] RW page (GUI) : FAIL
Error ID 0VB025
[4 ] RW channel (GUI) : FAIL
Error ID 0VB028
[5 ] Data mask : FAIL
Error ID 0VB006
[6 ] Macro + Micro8x2 tiling read : FAIL
Error ID 0VC006
[7 ] Byte swap macro+micro8x2 read : FAIL
Error ID 0VC018
[8 ] HOST_DATA/<f,b>/M2L : FAIL
Error ID 0TR014
640 x 480 - 8 bpp ( 75 Hz): TEST FAILURE
failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 17 18 19 20 21 22 23 48 ...
640 x 480 - 15 bpp ( 75 Hz): TEST FAILURE
failing bit : MDA0 16 17 18 19 20 21 22 23 ... MDB0 16 17 18 19 20 21 22 23 ...
640 x 480 - 16 bpp ( 75 Hz): TEST FAILURE
failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 16 17 18 19 20 21 22 23 ...
640 x 480 - 32 bpp ( 75 Hz): TEST FAILURE
800 x 600 - 8 bpp ( 75 Hz): TEST FAILURE
failing bit : MDA0 16 17 18 19 20 21 22 23 ... MDB0 17 18 19 20 21 22 23 48 ...
800 x 600 - 15 bpp ( 75 Hz): TEST FAILURE
failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 17 18 20 21 22 23 48 49 ...
800 x 600 - 16 bpp ( 75 Hz): TEST FAILURE
800 x 600 - 32 bpp ( 75 Hz): TEST FAILURE
1024 x 768 - 8 bpp ( 75 Hz): TEST FAILURE
1024 x 768 - 15 bpp ( 75 Hz): TEST FAILURE
failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 18 20 21 22 23 49 50 51 ...
1024 x 768 - 16 bpp ( 75 Hz): TEST FAILURE
1024 x 768 - 32 bpp ( 75 Hz): TEST FAILURE
failing bit : MDA0 1 2 3 4 7 8 9 10 ... MDB0 1 2 3 4 7 8 9 10 ...
[9 ] Line slopes/dir/P/solid : FAIL
Error ID 0TR010
failing bit : MDA0 16 17 18 19 20 21 22 23 ... MDB0 17 18 20 21 22 23 48 49 ...
Failure detected.
美丽的的谎言
2010-3-20 12:28
全部报错,先换AB通道首颗显存试试~
wbin0611
2010-3-20 13:15
请问怎么定位AB通道首颗显存?
美丽的的谎言
2010-3-20 14:02
正面下向上第一第三颗的对应的背面一颗 为A和B通道首颗
显卡修好了
2010-3-20 23:47
电压 正常? 核心有无损坏 , 地址线以及其他显存公用线,对地阻值 有没有 异常
wbin0611
2010-4-18 23:58
板主,谢谢你的回答,但我刚学维修,
请问你说的地址线在那里,还有着手修理一张花屏的显卡开始最先应该测量一些什么关键值呢?
还有一个问题,请问一张花屏的显卡如果任意拆掉一个显存,而原来花屏的样子没有变化,说明什么呢?
奥胜科技
2010-4-25 18:49
那只能说明故障点并不是拆掉的那个显卡上
