标题: IBM R50 开机自检 报告单 [打印本页] 作者: 蚂蚁扛起大象 时间: 2010-3-17 00:42 标题: IBM R50 开机自检 报告单 error
0271:check date and time settings
1802:Unauthorized network card is plugged in - power off and remove the minipci network card.
error
Resource Conflict - PCI Network Controller in slot 01
Bus:02,Device:02,Function:00
