标题: HP DV2000 V3000 INTEL 集显 上电时序 [打印本页]
作者: 重庆笔记本维修    时间: 2010-2-28 16:14
AKITA Power Sequence Table (adaptor in)
 Signal NameDescriptionMeasure Point
1BAT_Dgenerate by CMOS batteryD19pin1
2RTC_AUchinafix5 D18pin2
3RTC_RST# R171pin2
4AD+DCIN1U48pin5,6,7,8
5DCBATOUTAdaptor in
to generate DCBATOUT
R241pin1
6AC_OK Q29pin1
7AC_IN# Q29pin3
85V_AUchinafix5generate by TPS51120R213pin1
93D3V_AUchinafix5generate by TPS51120L15pin2
10KBC_3D3V_AUX G70
111D5V_AUX
12S5_ENABLEgenerate by KBCu13pin2
13PWR_S5_ENgenerate by u13u13pin4
145V_S5generate by TPS51120G40
153D3V_S5generate by U40U40pin1
16SB_RSMRST#generate by KBC to SBU33 pin38
17KBC_PWR_BTN# R1pin2
18PM_SLP_S4#generate by SBR368pin1
19PM_SLP_S3#generate by SBR367pin1
201D8V_S3generate by u22G61~G68
21DDR_VREF_S3 R417pin2
未完待续
作者: 重庆笔记本维修    时间: 2010-2-28 16:15
22        DDR_VREF_S0        generate by u17        G12~G14
23        5V_S0        generate by u38        U38Pin1
24        3D3V_S0        generate by u39        U39pin1
25        2D5V_S0        generate by u14        U14Pin2
26        1D5V_S0        generate by u34        G25~G29
27        1D05V_S0        generate by u22        G17~G23
28        CPUCORE_ON                r214pin2
29        G792_RST#        generate by u12        r138pin1
30        VGATE_PWRGD        generate by u11        G4
31        CLKEN#        generate by u11        G5
32        PWROK        generate by u50        U50pin11
33        VCC_CORE_S0        generate by u11( max8736ETL)        L26pin2
34        H_PWRGD        generate by u24(SB)        R79pin1
35        PCIRST1#        generate by u24(SB)        IC1pin119
36        PLT_RST#        generate by u24(SB)        U41pin13
37        RSTDRV#        generate by u41        U41pin11
38        PLT_RST1#                r371pin2
39        H_CPURST#        generate by u16(NB)        R39pin1
40        H_ADS#        bettween NB and CPU        TP_396
41        PCI_FRAME#        bettween SB and IC1        IC1pin23
42        LPC_LFRAME#                G76
搞定,要全的在下面。
作者: 重庆笔记本维修    时间: 2010-2-28 16:25
KAI power sequence
KAI power sequence.rar
3.66 KB, 下载次数: 513, 下载积分: 下载分 -2 分, 下载 1 次
作者: 流云风    时间: 2010-3-17 19:17
找了好久,自己发贴求都没人给,谢谢了
作者: 重庆笔记本维修    时间: 2010-3-21 20:02
这是我花三十大洋买的呢,修块进水机板子,找了好久没人理,拿到手后板子修好了就拿出来分享了
作者: ◣嗳情末班車    时间: 2010-3-25 08:30
发个图纸上去啊
作者: 重庆笔记本维修    时间: 2010-3-26 13:13
图纸资料里面有了
作者: asliyucegsm    时间: 2021-12-23 15:44
thank you friend
