楼主用的是ACER官方公布的方法。有兴趣的可以自己上去看看! E文的作者: 我会想你 时间: 2010-2-12 21:49
我很想知道楼是那样知道是BIOS坏的。很多原因会不开机的。你是用那样方法测出来的谢谢作者: 大泡泡 时间: 2010-2-12 22:23
晕 原来是官方公布的 哈哈哈作者: 红尘一笑哈哈 时间: 2010-2-18 19:17
看了楼主的意思只可意会不可言传啊作者: 瑞立科技 时间: 2010-2-18 19:33
宏基的小本,就爱丢程序。不过不拆机就可以刷,到没有试过作者: 电子维修学徒 时间: 2010-2-24 17:55
U盘不带引导也可以刷BIOS呀????????????作者: 现代电器 时间: 2010-3-10 15:26
Acer Aspire One BIOS Recovery
The AA1 has a built-in BIOS recovery routine, which makes it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies, that's why it's also known as crisis disk mode. Use at your own risk.
First format an USB flash drive with FAT.
Download the latest BIOS, extract all files from the zip file, put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD, that's important.
Turn the AA1 off, with the USB drive still connected, and make sure both battery and AC adapter are also connected.
Press Fn+Esc, keep it pressed and press the power button. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If it doesn't reboot by itself, but the power button still blinks, wait a few minutes before turning it off, and try again.作者: 现代电器 时间: 2010-3-10 15:28
网上找到的资料~
