查看: 3221|回复: 12
[显卡维修]
一块盈通9550 128M显卡花屏,有测试结果,大家帮忙看是那里的问题?
发表于 2010-2-7 10:21:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
测试结果:
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
Rv350 (0x4153) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 16 17 18 19 20 21 22 23 MDB0 16 17 18 19 20 21 22 23 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
    failing bit : MDA0 16 18 19 20 22 23 MDB0 17 18 20 21 22 23 44 45 ...
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
    failing bit : MDA0 16 17 19 21 22 MDB0 16 17 19 40 41 42 43 44 ...
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
    failing bit : MDA0 16 18 19 20 22 MDB0 16 17 18 19 20 21 22
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.8 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.8 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.8 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.8 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.8 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.8 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.8 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.8 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.8 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.8 not found
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.8 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.8 not found
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
     error : R051A.9 not found
     error : R052A.9 not found
     error : R053A.9 not found
     error : R055A.9 not found
     error : R061A.9 not found
     error : R062A.9 not found
     error : R063A.9 not found
     error : R065A.9 not found
     error : R071A.9 not found
     error : R072A.9 not found
     error : R073A.9 not found
     error : R075A.9 not found
Failure detected.
评分
参与人数 1下载分 +6 收起 理由
显卡修好了 + 6 不错的例子
查看全部评分
发表于 2010-2-7 10:43:01 | 只看该作者 �
先查U3然后再测U10周边相关的一切元件
发表于 2010-2-7 10:55:02 | 只看该作者 �
u3、u5先换掉看看
u10 应该也有问题,
换完u3 u5  再测试下看看
发表于 2010-2-7 17:19:16 | 只看该作者 �
告囍:感谢两位版主!此卡已修复。下面说一下修复的过程: 根据提示换U3和U5后,测
128M video memory.
[1  ] Fill                                                : FAIL
    Error ID 0VB001
    failing bit : MDA0 16 17 18 19 20 21 22 23 MDB0 47 56 57 58
    Error ID 0VB023
    failing bit : MDA0 16 17 18 19 20 21 22 23 MDB0 40 41 42 43 44 45 46 47 ...
    Error ID 0VB025
    failing bit : MDA0 16 18 19 20 22 23 MDB0 44 45 46 47 56 57 58 59
    Error ID 0VB028
    failing bit : MDA0 16 17 19 21 22 MDB0 40 41 42 43 44 45 46 47 ...
    Error ID 0VB006
    Error ID 0VC006
    failing bit : MDA0 16 17 18 19 20 21 22 23 MDB0 44 45 46 47 56 57
    Error ID 0VC018
    Error ID 0TR014
    Error ID 0TR010
Failure detected.
试结果如下:
发表于 2010-2-7 17:41:47 | 只看该作者 �
根据换后U3和U5的测试结果,出错的位置大概在U3,U6,U10,最后决定把这三个颗粒全部换掉,上机测试显示正常心中暗喜,测试结果如下:
R3MEMID version 1.12, (c) Copyright ATI Technologies Inc, 2004
RV350/M10 (0x4153) detected.
128M video memory.
[1  ] Fill                                                : PASS
[2  ] Data line toggle (GUI)                              : PASS
[3  ] RW column (GUI)                                     : PASS
[4  ] RW page (GUI)                                       : PASS
[5  ] RW channel (GUI)                                    : PASS
[6  ] Data mask                                           : PASS
[7  ] Macro + Micro8x2 tiling read                        : PASS
[8  ] Macro + Micro4x4 tiling write                       : PASS
[9  ] Byte swap macro+micro8x2 read                       : PASS
[10 ] Byte swap macro+micro4x4 write                      : PASS
[11 ] Marco+Micro8x2 alignment write                      : PASS
[12 ] Macro+Micro4x4 alignment read                       : PASS
[13 ] Movblit, 4 align, T                                 : PASS
[14 ] HOST_DATA/<f,b>/M2L                                 : PASS
[15 ] Line slopes/dir/P/solid                             : PASS
No failures detected.
搞定,再次感谢两位版主,其实再发本贴之前,我不会判断A卡的测试结果,根据你们的提示和我自己下载的颗粒定位资料,今天才懂了一点。
发表于 2010-2-8 09:21:04 | 只看该作者 �
其实U6是你在换掉其它显存后出现的错误,很有可能是虚焊或坏掉,既然修好了,恭喜楼主
发表于 2010-2-8 09:29:55 | 只看该作者 �
这个的问题其实就在U3  U5  U10上,U10很有可能是虚焊啦
发表于 2010-2-11 12:25:35 | 只看该作者 �
先用风枪吹一下
发表于 2010-2-13 12:58:19 | 只看该作者 �
4# 漯河奔腾科技
要怎判斷
是那顆顯存有問題啊
測出來的數據要怎判讀呢??
发表于 2010-2-14 10:57:00 | 只看该作者 �
9# hsiangga
根据显存的脚位图判断,N和A分区管理有一定的区别
发表于 2010-3-8 12:06:49 | 只看该作者 �
我的几块显卡马上也学着测试下,到时候还要麻烦新版帮忙了呵呵
发表于 2010-3-12 15:52:16 | 只看该作者 �
和我现在的这样一样问题。试一下看看
发表于 2010-3-12 19:15:07 | 只看该作者 �
谁可以发个R3软件给我我的信箱792948024@QQ.COM急。图标有花屏
