标题: please explain the funtionfor I/O or EC chip work [打印本页]
作者: netstrom    时间: 2010-1-24 17:01
my newbie for repair notebook . I don't understand for level process for I/O or then call EC chip . Everyone please explain the funtion of I/O or  so called  "EC Chip" EX.97551,WD910  by use schematic diagram  and tell me hoe to check if the IC work or not
作者: 孟德勇    时间: 2010-1-24 17:17
你的意思是问开机芯片,键盘管理芯片 I/O等的功能和工作时序和条件吗?
作者: netstrom    时间: 2010-1-24 17:34
YES!!!!!
作者: netstrom    时间: 2010-1-25 09:53
Everybody no answer to me!!!
