标题: HP NC6320 工程师维修经验共享 [打印本页]
作者: 零点人生    时间: 2010-1-17 23:59
PW00        上CPU   PW00        U32   BP
PW01        无PWR_GOOD_3        U20 PIN8空焊
PW00        无PLT_RST# 量到PM_PWROK#没送到SB        R1282   BP
PW01        I=0.29 无PM_PWROK#        量测到无PWR_GOOD_KBC#   R23BP
PW01        无PLT_RST#        U31     BP
PW00        无PM_PWROK        U32   BP    (U32拉低)
PW00        上电0.06掉到0.01;   +V3AL从3.3V掉到0.4V        U6       BP
PW00        上电充电灯闪!I=0.38,上CPU跑DEBUG"0A""1C"        量R326 100K电阻为55K,     D16  BP
PW01        上AC开机正常,上治具PWO1,无VCC-CORE        R9     BK
PW00        插电源开机,在治具上不开机        U1006   BP
PW01        上CPU   PW01        [
DP00        I=0.29 无H_CPURST#        查CLK_R3S_ICH48    U32BP
DP00        DEBUG  "E0"        R333  BP
DP00        DEBUG "B6"        CN16.125 PIN   OPEN
DP00        无H_CPURST#        R302  BP
DP00        无H_CPURST#        L20   BP  +V1.5S拉低
DP00        DEBUG "46"        U1006   BP
DP00        H_CPURST# 0.7, 量到VCCP 0.7        R259    MP
DP00        DEBUG "00" 无H_VREF        R198  BP
DP00        DEBUG "22"        R1274  BP
DP00         DEBUG "24"        U11   BP
DP00        DEBUG "BE"        R1269  BP
DP00        DEBUG "07"        U31     BP
DP00        DEBUG "49" 掉电        r247  mp
DP00        DEBUG "F0"        U10   BP
DP00        DEBUG "OA"        U27    BP
DP00        插WIRELESS开机无显示        R320    BP
DP00        I=0.38无H_CPURST#        U32     BP
DP00        DEBUG "BE"--"F0"        U32     BP
DP00        DEBUG"03"        U31     BP
DP00        DEBUG "97"        R411  MP
DP00        DEBUG "00"        U27   BP  PM_3S_KBCCPURST#信号不正常
DP00        DEBUG "B7"        U11   BP
DP00        DEBUG "B8"        量PCI_3S_CLKRUN#信号   U33BP
DP00        DEBUG"24"有时跑"00" +V2.5S 不正常        R232   BP
DP00        DEBUG "00"         R1210  BP
DP00        DEBUG"90""91"到"0A"           U32     BP
DP00        DEBUG "21"        U32     BP
DP00        DEBUG "00"量到U26第5PIN电压只有2.4V,        U32     BP
DP00        DEBUG "B7"---"BE"         U32     BP
DP00        DEBUG "0A","1C""2A"乱跑        U31     BP
DP00        DEBUG "D0"--"03"循环跑        U26    PP
DP00        DEBUG "35'"0E""98"乱跑        U32     BP
DP00        单核CPU开机正常,双核CPU跑"BE"        R1269  BP(MCH_BSEL1)
DP00        DEBUG "40"        量到CN16.1 OPEN     R1219  BP,   BIOS  PP
DP00        一跟DDR为OK ,两跟DDR为d0        U11  PIN524,560  SHORT
DP00        DEBUG "03"掉电        CN23PIN1.2  SHORT
DP00        DEBUG "E5"        U26    PP
DP00        DDR上槽跑"BE" 下槽开机        CN1002 PIN1,3 SHORT
DP00        DEBUG"23"        U31 BP<CLK_3S_ICH48不振荡>
LN05        WIRELESS侦测不到        R310  BP
LD17        静音灯常亮        U42   BP
DP12        DP12,切换黄色        U1007   空焊
LN00        刷不进MB号        U11   BP
SY01        进不了DOS        L30    KK
LN05        WIRELESS侦测不到,WIRELESS灯不亮        量CN1004 PIN11,13有CLK信号   U31 BP
SY01        DEBUG"5F"进DOS黑屏,按F1黑屏        U11   BP
LD18        WIRELESS灯不亮/灯常亮        Q53   BP
CO01        小头不良        U1013  BP
BT00        蓝牙灯不亮        C416   BP
BT00        开机Bluetooth灯闪一下就不亮.        U1013.15PIN OP(LPC_3S_FRAME#). C414,C416 BP
SY01        按8键后重启黑屏        U26   PP
LD18        WIRELESS灯关不灭        U27     BP
SY05        进XP蓝体白字        U26   PP
BP01        按P键自动关机        D20  极反
SY00        一直跑滚动条        U32   BP
SY01        进DOS时显示Loading FreeDos        U11(北桥)   BP
SY00        进XP一会儿蓝体白字        U32   BP
SY00        进选择界面然后跑滚动条一会儿自动重启        U32   BP
OT00        TPM不过        U45   BP
LD18        WIRELESS灯不亮,量测到D42 PIN1无电压        D42   BP
SY00        用电池进XP一会儿当机        R293  BP
OT00        无充电符号        C1058  OP
OT00        进XP反应慢,进DOS/XP选择画面慢        U1001  BP
PW01        不上CPU开机正常.上CPU和DDR电流0.06跳到1.98以上        R1143 OP
DP12        LCM有显,CRT无显        R355,R354 BP
HD01        不抓HDD        X2 BP(CLK_R_SATA1,CLK_R_SATA1振荡不正常)
MD06        Modem拨号有杂音/Modem不良        北桥BP
DP12        V2.5上电就产生且拉升到3.3V        U3 BP
dp00        debug"b5"        1:U11   BP       2:CPU NMI信号空焊
DP00        无CPURST        2.5V产生异常,Q24空焊
DP00        0b        R1279 BP
DP00        25        U11   BP或L7 BP
DP00        D2过后"08"        U31 BP
DP00        电流"0.36",无CPURST        L9有阻值,将1.5V拉低
DP00        1.73 CPU OK,1.66CPU" 08"        U31 BP
DP14        用电池进XP在滚动条画面有条纹,AC正常        U1018  BP
CD01        DVD测试98% FAIL,提示与温度有关        先后换过南北桥,CLK,SMSC等,最后确定 U21  BP
LN00        刷不进MB号,可手输入        先后换过南北桥,CLK,最后试换SMSC OK
kb00        Delete键不良        换过接口,最后换南桥OK
BP01        放电时黑屏一下后显示正常        ]
DV06        DVD偵測到也能讀取 但測試第九站DVD後不跳站  測試不良        u21与CPU连线断线
LN00        刷不进MB号,可手输入,第一次刷SCANER有光,再刷后没        更换南桥OK
作者: hz9xdn    时间: 2010-1-31 11:50
今天接到一台6320机器。问题怪。机器拿来没硬盘。有时可以开机正常。用光盘进PE有时死机。进去后重启没起来,在强行关机,在开前几下都开不起来。不进PE重启是正常的。但有是开不了机。要是出现开不了机肯定是连续好几次开不了。在你的分享中没有找的相关问题。我也是无从下手。
作者: 江南秀士    时间: 2014-6-18 14:54
工程师维修经验,这么强,楼主是行家里手了
