查看: 2779|回复: 6
945G主板的问题
发表于 2010-1-14 19:59:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
我一台HP电脑945G主板 原配奔腾D3.0CPU 现在改为E1400CPU 后 开机风扇转下停了 换电源后故障依旧 请问各位大虾什么原因   在线学习
发表于 2010-1-14 20:06:02 | 只看该作者 �
好象不支持 E1400的U  我不明白LZ为什么要换U
发表于 2010-1-14 20:09:09 | 只看该作者 �
那款CPU 发热太大 被我卖了 现在换上E1400  65纳米的   可是出现开机风扇转下停了
发表于 2010-1-14 20:09:24 | 只看该作者 �
不支持CPU吧。去查一下主板支不支持,能不能刷BIOS让其支持这U。
发表于 2010-1-14 20:12:19 | 只看该作者 �
惠普只测试过如下型号的CPU,
Processor and Speed* – One of the following
Intel Celeron D Processors
Intel Celeron D 331 Processor
(2.66-GHz, 256K L2 cache, 533-MHz FSB)
X
X
Intel Celeron D 336 Processor
(2.80-GHz, 256K L2 cache, 533-MHz FSB)
X
X
Intel Celeron D 346 Processor
(3.06-GHz, 256K L2 cache, 533-MHz FSB)
X
X
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor
(2.8-GHz, 1 MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium 4 524 Processor
(3.06-GHz, 1-MB L2 cache, 533-MHz FSB)
X
X
Intel Pentium 4 541 Processor
(3.2-GHz, 1-MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium 4 620 Processor
(2.8-GHz, 2-MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium 4 630 Processor
(3.0-GHz, 2 MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium 4 631 Processor
(3.0-GHz, 2-MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium 4 640 Processor
(3.2-GHz, 2 MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium 4 641 Processor
(3.2-GHz, 2-MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium 4 650 Processor
(3.4-GHz, 2 MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium 4 651 Processor
(3.4-GHz, 2-MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium 4 661 Processor
(3.6-GHz, 2-MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium D Processors:
Intel Pentium D 805 Dual Core Processor
(2.66-GHz, 2x1MB L2 cache, 533-MHz FSB)
X
X
Intel Pentium D 820 Dual Core Processor
(2.8-GHz, 2x1MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium D 915 Dual Core Processor
(2.8-GHz, 2x2MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium D 925 Dual Core Processor
(3.0-GHz, 2x2MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium D 930 Dual Core Processor
X
X
Intel Pentium D 940 Dual Core Processor
(3.2-GHz, 2x2MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium D 945 Dual Core Processor
(3.4-GHz, 2x2MB L2 cache, 800-MHz FSB)
X
X
Intel Pentium D 950 Dual Core Processor
发件人: rujing_520 [mailto:rujing_520@163.com]
发送时间: 2009年12月30日 8:58
收件人: Huang, Zhong Yan (TSDO-GSC-DL-PSG-PC)
主题: 来自rujing_520@163.com的邮件
重要性: 高
对了 我想问一下 这款机子  DX7208  主版 能上奔腾 E5200 双核处理器的吗 ?速回
发表于 2010-1-14 20:13:02 | 只看该作者 �
型号是HP  DX7208 商务机
发表于 2010-1-14 21:34:20 | 只看该作者 �
刷BIOS试一下,在换一下风扇。
