查看: 4309|回复: 0
求BIOS更改方法,请大大们帮下
发表于 2009-12-27 16:57:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广东广州 来自 广东广州
得了个HP的BIOS SLIC2.1的表,想在Single Link Aric BIOS里面再加一点内容,自己用工具转换格式不正常,又无从入手,请大大们帮指导一下。或给报酬。
现在解密的表如下。
* Intel ACPI Component Architecture
* AML Disassembler version 20090220
* Disassembly of SLIC.aml, Sun Dec 27 09:17:54 2009
* ACPI Data Table [SLIC]
* Format: [HexOffset DecimalOffset ByteLength]  FieldName : FieldValue
[000h 000  4]                    Signature : "SLIC"    /* Software Licensing Description Table */
[004h 004  4]                 Table Length : 00000176
[008h 008  1]                     Revision : 01
[009h 009  1]                     Checksum : FE
[00Ah 010  6]                       Oem ID : "HPQOEM"
[010h 016  8]                 Oem Table ID : "SLIC-CPC"
[018h 024  4]                 Oem Revision : 42302E31
[01Ch 028  4]              Asl Compiler ID : "AWRD"
[020h 032  4]        Asl Compiler Revision : 00000000
Raw Table Data
  0000: 53 4C 49 43 76 01 00 00 01 FE 48 50 51 4F 45 4D  SLICv.....HPQOEM
  0010: 53 4C 49 43 2D 43 50 43 31 2E 30 42 41 57 52 44  SLIC-CPC1.0BAWRD
  0020: 00 00 00 00 00 00 00 00 9C 00 00 00 06 02 00 00  ................
  0030: 00 24 00 00 52 53 41 31 00 04 00 00 01 00 01 00  .$..RSA1........
  0040: 5B AB 60 56 BC 58 1E E8 C1 D2 A1 5C E5 4F BB FD  [.`V.X.....\.O..
  0050: 1D A9 8C 94 B4 AE 08 11 DC 13 59 D3 7F F6 3E 87  ..........Y...>.
  0060: 31 B9 95 74 10 DA 3B A4 5B B5 19 82 7C 39 D7 0D  1..t..;.[...|9..
  0070: 7C 22 AC 1C 2A 84 E9 0A 88 6D FA B1 E2 D8 E8 21  |"..*....m.....!
  0080: 96 E1 2E 68 9A BF 44 45 3E 3C 8E 99 90 DE 37 38  ...h..DE><....78
  0090: 57 0B 92 15 BC DE FF F2 07 7E B5 40 8C 51 3A C3  W........~.@.Q:.
  00A0: 02 48 F6 13 12 72 FB 42 78 E6 47 88 54 C7 B0 F0  .H...r.Bx.G.T...
  00B0: 93 9E FB 04 B7 B8 B8 90 DE DB ED 32 E1 FB 54 A6  ...........2..T.
  00C0: 01 00 00 00 B6 00 00 00 00 00 02 00 48 50 51 4F  ............HPQO
  00D0: 45 4D 53 4C 49 43 2D 43 50 43 57 49 4E 44 4F 57  EMSLIC-CPCWINDOW
  00E0: 53 20 01 00 02 00 00 00 00 00 00 00 00 00 00 00  S ..............
  00F0: 00 00 00 00 00 00 71 06 CA B4 F1 F6 6F DA 3A 30  ......q.....o.:0
  0100: 39 DA AC E8 70 33 85 D3 B1 D7 A7 6F 14 B7 8A D3  9...p3.....o....
  0110: 3D 53 9A F3 71 D9 28 3D 6C 7C 3A 06 81 AD 0D E5  =S..q.(=l|:.....
  0120: C2 A7 67 9E CE 3F FD 33 62 4C B4 5B 51 5F 0A 25  ..g..?.3bL.[Q_.%
  0130: 32 9F 7D 13 65 E3 5A AE AE F3 7B 25 81 13 86 CF  2.}.e.Z...{%....
  0140: 64 14 1B F5 F1 6A CB 64 3A C6 93 6F 28 0E 53 43  d....j.d:..o(.SC
  0150: 1A 44 AE 4F 84 76 46 D8 23 5F 6D 5D A6 23 64 CF  .D.O.vF.#_m].#d.
  0160: 38 83 8B DF DF 2C 3A 3F 2C 73 DF E6 B8 9D D1 B3  8....,:?,s......
  0170: FE BF FE B0 3C D7                                ....<.
