标题: Replaced CCFL lamp 代替CCFL灯管 [打印本页] 作者: 自由的 时间: 2009-12-11 19:23 标题: Replaced CCFL lamp 代替CCFL灯管 Customer brought a Compaq 6715b Notebook that had fell on the floar. There was no light light on screen, but you could see dark picture in the background. I connected another lcd screen and it was working fine. I took out good CCFL lamp from broken LCD display (same size, but different manufacturer). It took a long time to carefully dissasemble LCD screen, clean the broken glass particles and reassemble everything back. I was realy happy to see that everything is working fine when I put it back together .
顾客带来了康柏6715b笔记本电脑已经在floar下跌。目前还没有银幕之光灯,但你可以看到黑暗背景图片。本人有关联的另一个液晶屏幕和它工作正常。我拿出来自破碎液晶显示器好CCFL灯管(大小相同,但不同的制造商)。它花了很长时间,仔细dissasemble液晶屏幕,清理碎玻璃微粒和重新组合的一切回来。我真的很高兴地看到,一切工作正常,当我把它重新走到一起。作者: 易安宁 时间: 2009-12-11 19:41 英文好,还是老外在中国从事维修啊?作者: 自由的 时间: 2009-12-11 19:48 Working on notebook maintenance in Belgrade, Serbia, Europe
:)笔记本工作在贝尔格莱德,塞尔维亚,欧洲维修作者: 红尘一笑哈哈 时间: 2009-12-11 19:56
应该是老外做维修哦作者: weiqigo 时间: 2009-12-11 20:13
哈哈,翻译得狗屁不通!真是老外在做维修还是用翻译软件译的英文呀?作者: 自由的 时间: 2009-12-12 01:51
Sorry, weiqigo, I am doing my best to try to translate with google.
But I really do maintenance and help that I am getting from ChinaFix is realy precious.
