查看: 2425|回复: 6
[显卡维修]
FX5200花屏 用MATS476测试结果如下,请帮忙分析一下
发表于 2009-11-25 21:45:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
修修吧-电脑维修站 详细出处参考:http://www.xiuxiu8.net/hardware/shengkaxianka/20080408/4749.html
FX5200 128M
在纯DOS下不花屏,只有有色彩显示,就会花         谢谢!使用MATS476,测试结果如下:
Tested from 0 MB to 128 MB.
    LANE     E_BANK0 ERRORS
FBA[31: 0]           17438
FBA[63:32]           17438
FBC[31: 0]        17858474
FBC[63:32]           17438
External Bank 0 Failing bits:
   A00 A01 A02 A03 A04 A05 A06 A07 A08 A09 A10 A11 A12 A13 A14 A15
   A16 A17 A18 A19 A20 A21 A22 A23 A24 A25 A26 A27 A28 A29 A30 A31
   A32 A33 A34 A35 A36 A37 A38 A39 A40 A41 A42 A43 A44 A45 A46 A47
   A48 A49 A50 A51 A52 A53 A54 A55 A56 A57 A58 A59 A60 A61 A62 A63
   C00 C01 C02 C03 C04 C05 C06 C07 C08 C09 C10 C11 C12 C13 C14 C15
   C16 C17 C18 C19 C20 C21 C22 C23 C24 C25 C26 C27 C28 C29 C30 C31
   C32 C33 C34 C35 C36 C37 C38 C39 C40 C41 C42 C43 C44 C45 C46 C47
   C48 C49 C50 C51 C52 C53 C54 C55 C56 C57 C58 C59 C60 C61 C62 C63
Read    Error Count: 143251
Write   Error Count: 17767537
Unknown Error Count: 0
ADDRESS  EXPECTED  ACTUAL  REREAD1  REREAD2  REREAD3  TYPE  P L E I ROW  COL BO
076ab334 00000000 76060000 76060000 76060000 76060000 WRITE C 0 0 1 1daa 133 1
076ab330 00000000 27200000 27200000 27200000 27200000 WRITE C 0 0 1 1daa 132 0
076ab314 00000000 22010000 22010000 22010000 22010000 WRITE C 0 0 1 1daa 131 1
076ab310 00000000 10350000 10350000 10350000 10350000 WRITE C 0 0 1 1daa 130 0
076aa334 00000000 3ac10000 3ac10000 3ac10000 3ac10000 WRITE C 0 0 1 1daa 033 1
076aa330 00000000 009f0000 009f0000 009f0000 009f0000 WRITE C 0 0 1 1daa 032 0
076aa314 00000000 52840000 52840000 52840000 52840000 WRITE C 0 0 1 1daa 031 1
076aa310 00000000 e6240000 e6240000 e6240000 e6240000 WRITE C 0 0 1 1daa 030 0
076a9334 00000000 160c0000 160c0000 160c0000 160c0000 WRITE C 0 0 0 1daa 133 1
076a9330 00000000 042e0000 042e0000 042e0000 042e0000 WRITE C 0 0 0 1daa 132 0
076a9314 00000000 37930000 37930000 37930000 37930000 WRITE C 0 0 0 1daa 131 1
076a9310 00000000 d4040000 d4040000 d4040000 d4040000 WRITE C 0 0 0 1daa 130 0
076a8334 00000000 fe900000 fe900000 fe900000 fe900000 WRITE C 0 0 0 1daa 033 1
076a8330 00000000 c1400000 c1400000 c1400000 c1400000 WRITE C 0 0 0 1daa 032 0
076a8314 00000000
发表于 2009-11-25 22:20:59 | 只看该作者 �
要是没有掉件的话·· 先加下焊
发表于 2009-11-26 09:04:24 | 只看该作者 �
报告是全报错 先加焊一下GPU吧 如果不行的话很有可能是GPU挂了 也有可能是测试软件出错
发表于 2009-11-26 09:48:21 | 只看该作者 �
GPU 加焊~不行的话就只能换GPU 了
发表于 2009-11-26 23:24:35 | 只看该作者 �
加焊GPU 换测试软件 GPU挂了
发表于 2009-11-27 00:39:48 | 只看该作者 �
GPU加焊试试
发表于 2009-11-27 23:20:59 | 只看该作者 �
楼主这块显卡修好没有?
