R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
RV370/M22 A12b (0x5b63) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : FAIL
Error ID G0VB001
1024 x 768 - 16 bpp ( 60 Hz): TEST FAILURE
failing bit : MDA0 19 21 22 23 59 60 61 62 ...
[2 ] Data line toggle (GUI) : FAIL
Error ID G0VB023
failing bit : MDA0 16 17 18 19 20 21 22 23 ...
[3 ] RW column (GUI) : FAIL
Error ID G0VB024
[4 ] RW page (GUI) : FAIL
Error ID G0VB025
[5 ] RW channel (GUI) : FAIL
Error ID G0VB028
[6 ] Data mask : FAIL
Error ID G0VB006
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
[7 ] Macro + Micro8x2 tiling read : FAIL
Error ID G0VC006
[8 ] Macro + Micro4x4 tiling write : FAIL
Error ID G0VC009
[9 ] Byte swap macro+micro8x2 read : FAIL
Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write : FAIL
Error ID G0VC021
昨天出了一件奇怪的问题,我短接引脚45脚,和不短接我发现没有什么区别,我弄下正面的一个芯片测试结果是0-7 弄下反面的再测试还是0-7,我不知道如何是好,我该看什么地方的检测值啦,mats的我会定位,这种我都不知道看哪里,现在把芯片全上上了,花得更历害了,坛中的师傅们帮我再看下作者: 希望的寄托 时间: 2009-11-26 09:26
128M video memory.
[1 ] Fill : FAIL
Error ID G0VB001
failing bit : MDA0 0 1 2 5 8 9 10 11 ...
Error ID G0VB023
failing bit : MDA0 0 1 2 3 4 5 6 7 ...
Error ID G0VB024
Error ID G0VB025
Error ID G0VB028
Error ID G0VB006
Error ID G0VC006
Error ID G0VC009
Error ID G0VC018
Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write : FAIL
Error ID G0VC052
[12 ] Macro+Micro4x4 alignment read : FAIL
Error ID G0VC057
[13 ] Movblit, 4 align, T : FAIL
Error ID G0TR055
1024 x 768 - 16 bpp ( 75 Hz): TEST FAILURE
error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L : FAIL
Error ID G0TR014
640 x 480 - 8 bpp ( 75 Hz): TEST FAILURE
error : R051A.14 not found
640 x 480 - 15 bpp ( 75 Hz): TEST FAILURE
error : R052A.14 not found
640 x 480 - 16 bpp ( 75 Hz): TEST FAILURE
error : R053A.14 not found
640 x 480 - 32 bpp ( 75 Hz): TEST FAILURE
error : R055A.14 not found
800 x 600 - 8 bpp ( 75 Hz): TEST FAILURE
error : R061A.14 not found
800 x 600 - 15 bpp ( 75 Hz): TEST FAILURE
error : R062A.14 not found
800 x 600 - 16 bpp ( 75 Hz): TEST FAILURE
error : R063A.14 not found
800 x 600 - 32 bpp ( 75 Hz): TEST FAILURE
error : R065A.14 not found
1024 x 768 - 8 bpp ( 75 Hz): TEST FAILURE
error : R071A.14 not found
1024 x 768 - 15 bpp ( 75 Hz): TEST FAILURE
error : R072A.14 not found
error : R073A.14 not found
1024 x 768 - 32 bpp ( 75 Hz): TEST FAILURE
error : R075A.14 not found
[15 ] Line slopes/dir/P/solid : FAIL
Error ID G0TR010
error : R051A.15 not found
error : R052A.15 not found
error : R053A.15 not found
error : R055A.15 not found
error : R061A.15 not found
error : R062A.15 not found
error : R063A.15 not found
error : R065A.15 not found
error : R071A.15 not found
error : R072A.15 not found
error : R073A.15 not found
error : R075A.15 not found
Failure detected.
128M video memory.
[1 ] Fill : FAIL
Error ID G0VB001
Error ID G0VB023
Error ID G0VB024
Error ID G0VB025
Error ID G0VB028
Error ID G0VB006
Error ID G0VC006
Error ID G0VC009
Error ID G0VC018
Error ID G0VC021
Error ID G0VC052
Error ID G0VC057
Error ID G0TR055
Error ID G0TR014
Error ID G0TR010
Failure detected.
大家应该看到了这两个地方吧,我想让师傅们解释下,这是什么回事,为什么会有两个的位数不一样啦,每次都不一样,两个各表示什么啦
一般看哪一个为准啦,谢谢师傅们指点下,我就是这个地方不太明白,每次都用猜。RV370/M22 A12b (0x5b63) detected.
128M video memory.
[1 ] Fill : FAIL
Error ID G0VB001
Error ID G0VB023
failing bit : MDA0 0 1 2 3 4 5 6 7 ...作者: 多多 时间: 2009-11-26 14:29
你的焊工有问题技术不过关作者: 希望的寄托 时间: 2009-11-26 14:38
那我再焊一次了作者: 希望的寄托 时间: 2009-11-28 09:09 本帖最后由 希望的寄托 于 2009-11-28 09:19 编辑
