Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
Radial Offset Table:
Head 0 Offset = 1458
Head 1 Offset = 1A13
Head 2 Offset = 1A13
Head 3 Offset = 1A13
Head 4 Offset = 1A13
Head 5 Offset = 1A13
Radial ID Delta Offset Table - RPO:
Head 0 Offset = 0
Head 1 Offset = E9C1
Head 2 Offset = E9C1
Head 3 Offset = E9C1
Head 4 Offset = E9C1
Head 5 Offset = E9C1
Disk D0
RPO Calibration!
Head 0 Offset = 0
Head 1 Offset = E406
Head 2 Offset = E406
Head 3 Offset = E406
Head 4 Offset = E406
Head 5 Offset = E406
Head 00
Zone 00: 00018 - 03B77 1351 (0547) 849.193
Zone 01: 03B78 - 07673 1320 (0528) 823.790
Zone 02: 07674 - 09DB5 1276 (04FC) 803.225
Zone 03: 09DB6 - 0C0AB 1237 (04D5) 780.644
Zone 04: 0C0AC - 0DDF7 1210 (04BA) 760.645
Zone 05: 0DDF8 - 0F9E5 1173 (0495) 740.322
Zone 06: 0F9E6 - 113DF 1144 (0478) 720.967
Zone 07: 113E0 - 13DDD 1100 (044C) 688.064
Zone 08: 13DDE - 1603D 1045 (0415) 659.032
Zone 09: 1603E - 1871B 990 (03DE) 624.193
Zone 0A: 1871C - 1A9AD 935 (03A7) 592.258
Zone 0B: 1A9AE - 1D027 880 (0370) 553.845
Zone 0C: 1D028 - 1ECAB 825 (0339) 524.653
Zone 0D: 1ECAC - 20CE5 770 (0302) 489.081
Zone 0E: 20CE6 - 22423 715 (02CB) 457.815
Zone 0F: 22424 - 23459 660 (0294) 418.548
Reserve: 15B65 - 15C92 640 (0280) 444.193
Total KBAs = 095483C5
EP=1, TA=1, HiGain=1, OTRd=1, Early Rd=0, Splash=1, Reload=1, NPML=1, MRBias=1
Bst/Zap=1, SrvoThrsh=1, RunOut=1, MaxECC=1, ECC 2=1, ECC 1=1, ECC 0=1
Data=40, Write=80, ID=FF, DER=001F, RdWrOpts=F7FF
All Hds 0-0, All Cyls, Rnd Data
Hd 0, Cyls 00018 - 23459
Performing AFC Zone Cal
ACFC Calibration:
EP=0, TA=0, HiGain=0, OTRd=0, Early Rd=0, Splash=0, Reload=0, NPML=0, MRBias=0
Bst/Zap=0, SrvoThrsh=0, RunOut=0, MaxECC=0, ECC 2=1, ECC 1=1, ECC 0=1
Data=02, Write=40, ID=1E, DER=0000, RdWrOpts=0007
HEAD CLEARANCE MEASUREMENT
Disable AFC 2x+
Zap Eng Dis
Zap Rd Dis
Alt = sealevel
Error: HdClr Measurements file could not be opened!
afhCert structure may not be valid!
Cant seek to 7822. Min is 4294843972, Max is 4294844368
Error: HdClr Measurements file read incomplete!
Head Clearance structure may not be valid!
Seek To 72(73).0
Waiting for AFC 1x to converge.
DZF 877500,M 116,N 3,BPW 3088
Screen Trk
Ov 0,Od 0,Iw 0,RH 0,WH 0
Cleaning trks
Pos Retest W+H HO
0 0 0.391 0.393
1 0 0.442 0.430
2 0 0.432 0.430
3 0 0.391 0.379
Hd,Zn,Ov,Od,Iw,PH,WH,RH,WRdClr,HRdClr
0, 0, 8, E, 9,26,1C,1F, 0.392, 0.392
0, 1, 8, E, 9,28,20,22, 0.424, 0.416
0, 2, 8, E, 9,2A,22,23, 0.443, 0.431
0, 3, 8, E, 9,2A,22,23, 0.439, 0.431
0, 4, 8, E, 9,2A,22,23, 0.439, 0.431
0, 5, 8, E, 9,2A,22,23, 0.439, 0.431
0, 6, 8, E, 9,29,22,23, 0.439, 0.431
0, 7, 8, E, 9,29,22,23, 0.439, 0.431
0, 8, 8, E, 9,29,22,23, 0.435, 0.431
0, 9, 8, E, 9,29,22,23, 0.435, 0.431
0, A, 8, E, 9,29,21,22, 0.435, 0.431
0, B, 8, E, 9,28,21,22, 0.435, 0.431
0, C, 8, E, 9,28,21,22, 0.431, 0.431
0, D, 8, E, 9,27,20,20, 0.424, 0.420
0, E, 8, E, 9,25,1F,1E, 0.408, 0.400
0, F, 8, E, 9,23,1D,1C, 0.392, 0.380
0,10, 6, E, 7,29,26,23, 0.435, 0.431
Restoring Drive State
Enable AFC 2x+
Channel Srvo Table
Head Addr VGA SATT Tap5 Tap6 Tap3 Tap7 Tap2 Tap8 Tap9 XDC P_GN
00 8766 7F 04 A9 CA 66 99 91 9C 77 9B 02
Adapt Servo Zone 09
Adapt Servo 000173ac.00
Adapts Loaded
Rbck DATA load
NPML 00
Test 000173ac.00 10807c26 BER 0300094c
Adjust ATTR 02 VGAS 7f VGAR 62 FREQR 81 Read 0043 within _ATT
MRASYM 80 10808ba8 BER 0300094c
MRASYM 75 10804d9a BER 0300094c update 75 hold
Servo Zone 13, OD [000151D2.0,FCC6,02C6,C0]
Left Bath = FE59, Right Bath = FF2A : Pick (FEC1) ( Min/Max AGC 7AFC )
Servo Zone 14, OD [00016398.0,FD5B,035B,C0]
Left Bath = FEE7, Right Bath = FFBF : Pick (FF53) ( Min/Max AGC 77F9 )
Servo Zone 15, OD [0001755E.0,FDEF,03EF,C0]
Left Bath = FF8A, Right Bath = 0067 : Pick (FFF8) ( Min/Max AGC 76FB )
Servo Zone 16, OD [00018724.0,FE84,0484,C0]
Left Bath = 002A, Right Bath = 0100 : Pick (0095) ( Min/Max AGC 79F2 )
Zone 9 - 1603e.0 Target = f (2)
09 0A 0B 0C 0D 0E 0F 10 11 Loops Value
0000 0000 0000 0002 0199 01C8 0022 0000 0000 0003 0003
Test 000173ac.00 00011b61 BER 0000000a
Servo Zone 0, OD [00000020.0,F1BF,F7BF,C0]
Left Bath = F4D6, Right Bath = F57F : Pick (F52A) ( Min/Max AGC 8DFF )
Servo Zone 1, OD [000011E6.0,F253,F853,C0]
Left Bath = F556, Right Bath = F605 : Pick (F5AD) ( Min/Max AGC 8DFF )
Servo Zone 2, OD [000023AC.0,F2E8,F8E8,C0]
Left Bath = F5CF, Right Bath = F680 : Pick (F627) ( Min/Max AGC 8AFF )
Servo Zone 3, OD [00003572.0,F37C,F97C,C0]
Left Bath = F652, Right Bath = F706 : Pick (F6AC) ( Min/Max AGC 8BFF )
Servo Zone 4, OD [00004738.0,F411,FA11,C0]
Left Bath = F6CA, Right Bath = F77A : Pick (F722) ( Min/Max AGC 8AFF )
Zone 0 - 00018.0 Target = f (2)
0000 0000 0000 001E 00E3 002B 0001 0000 0000 0001 0004
Test 00003b57.00 000228e3 BER 00000050
Test 000173ac.00 00011498 BER 00000009
Adjust ATTR 02 VGAS 79 VGAR 62 FREQR 83 within _ATT
MRASYM 75 00012e7b BER 0000000b
MRASYM 4f 0001223a BER 00000008 update 4f hold
Default Tap Weight 00000000 Settle Tap Weight 00000154
XDCTAP 9b 00021f5f BER 00000000 adapt
XDCTAP 9c 00022312 BER 00000000 hold
PREAMP GAIN 02
Adjust ATTS 02 VGAS 78 VGAR 71 FREQR 7f VGAS_ADJUST 07 within _ATT
SV TAP5 Lower 0020 Upper 00df Step 0006 Right 1f Mask 00001000
Default 007c 00022295 BER 00000000
Floor 1 20 00027932 00032502
Left 1 0080 000235f2
Middle 1 00af 0002485e
Right 1 00df 00027932
Lowest 1 0092 00022be8
Z = -A1/(2*A2) : C000
X = Z + Xavg : C00F
Curve 00d4 00026ea4
New 00af 000244e2 BER 00000000
000241ee BER 00000000 _ATT 02 VGAS 84 VGAR 6d FREQR 84 Taps frozen read adapt
Current Tap Weight 00005085 diff ffffaf7b tap limits
00024c7d BER 00000000 _ATT 02 VGAS 84 VGAR 6d FREQR 7b Taps frozen read adapt
Current Tap Weight 00000012 diff 00005073 tap limits
00025154 BER 00000000 _ATT 02 VGAS 85 VGAR 6b FREQR 80 Taps frozen read adapt
Current Tap Weight 0000003b diff ffffffd7 Save servo Force servo update
Rbck Default DATA load
Test 000173ac.00 00014b38 BER 00000fff
HiTemp Bias BackOff Head 0 1 2 3
7
Media 0000
Adapt Data Zone 00
Test 00001dc7.00 00022517 BER 00000053
Map 00001dc7.00 Defects 0000
Test 00001dc7.00 00021467 BER 0000004e
Adapt Data 00001dc7.00
Rbck DATA load
NPML 00
Test 00001dc7.00 00020c56 BER 00000041
Adjust ATTR 02 VGAS 87 VGAR 63 FREQR 82 within _ATT VGAR FREQR
MRASYM 80 0002533e BER 0000005e
MRASYM 4a 00022229 BER 0000004c update 4a hold
Test 00000020.00 0002440b BER 00000067
Servo Zone 00 OD OFST Lower f4ca Upper f589 Step 0006 Right 1f Mask 00004340
Default f52a 00025060 BER 0000006f
Floor 1 1a 00055597 00055597
Left 1 f500 000546a6
Middle 1 f532 000253b6
Right 1 f565 0004bc07
Lowest 1 f530 000253b6
Z = -A1/(2*A2) : 0000
X = Z + Xavg : 000F
Curve f524 000276a8
New f532 000254e9 BER 0000006a
Test 000011e6.00 00020d62 BER 00000037
Servo Zone 01 OD OFST Lower f54d Upper f60c Step 0006 Right 1f Mask 00004340
Default f5ad 000213fd BER 0000002d
Floor 1 1a 0004c2ea 0004c2ea
Left 1 f589 00044e84
Middle 1 f5b8 00021e73
Right 1 f5e8 0003ed90
Lowest 1 f5b9 000219e4
X = Z + Xavg : 000F
Curve f5a7 000242e8
New f5b8 000215fc BER 00000036
Test 000023ac.00 000211bb BER 0000004c
Servo Zone 02 OD OFST Lower f5c7 Upper f686 Step 0006 Right 1f Mask 00004340
Default f627 00021791 BER 00000050
Floor 1 1a 0004d3df 0004d3df
Left 1 f603 00048d6a
Middle 1 f635 0002048a
Right 1 f668 00045113
Lowest 1 f633 0002048a
X = Z + Xavg : 000F
Curve f621 00025085
New f635 00020abf BER 00000041 AUTO
Test 00003572.00 0001ebd7 BER 00000033
Servo Zone 03 OD OFST Lower f64c Upper f70b Step 0006 Right 1f Mask 00004340
Default f6ac 0001ef9b BER 00000038
Floor 1 17 00040ba9 00040ba9
Left 1 f688 0003b23e
Middle 1 f6b4 0001fc52
Right 1 f6e1 0003deed
Lowest 1 f6b2 0001fc52
X = Z + Xavg : 000F
Curve f6a6 00022672
New f6b4 00020a36 BER 00000030
Adjust ATTR 02 VGAS 89 VGAR 66 FREQR 82 within _ATT VGAR FREQR
Test 00001dc7.00 00020529 BER 0000002f
Noise target 00000000
Rbck Noise OFF
Rbck DATA save
Test 00001dc7.00 0001ff3c BER 00000040
MRASYM 4a 000209c3 BER 00000038
MRASYM 4c 000214bf BER 00000044 hold
PRECOMP Lower 0000 Upper 000a Step 0001 Right 0a Mask 00000004
Default 0001 0001f895 BER 0000002d
Floor 1 0b 0001f401 00029cf3
Left 1 0000 0001f401
Middle 1 0000 0001f401
Right 1 0000 0001f401
Lowest 1 0000 0001f401
Z = -A1/(2*A2) : FFFA
X = Z + Xavg : FFFF
Curve 0009 00035be9
New 0000 0001eb3e BER 00000032
Test 00001dc7.00 0001dd4b BER 00000029
XDCTAP 90 0001f009 BER 0000002f adapt
XDCTAP 84 0001f133 BER 00000033 hold
CUTOFF Lower 0524 Upper 0615 Step 0002 Right 13 Mask 00000348
Default 060e 00067a33 BER 00000000
Floor 1 09 00068c35 0006a34a
Left 1 060f 000680e0
Middle 1 0611 000696af
Right 1 0615 00066f2f
Lowest 1 0613 0006683a
New 0611 00068246 BER 00000003
BOOST Lower 0000 Upper 0016 Step 0001 Right 16 Mask 00000360
Default 0014 0006952b BER 00000004
Floor 1 17 0006c684 0007c24e
Left 1 0013 0006be90
Middle 1 0014 0006a788
Right 1 0016 0006c684
Lowest 1 0014 0006a788
Z = -A1/(2*A2) : FFE7
X = Z + Xavg : FFF2
Curve 0015 0006c1bf
New 0014 00069577 BER 0000000a
TAPDELT Lower 0004 Upper 000d Step 0001 Right 09 Mask 00000350
Default 0006 00068d2e BER 00000004
Floor 1 0a 000666e8 0006d658
Left 1 0004 000666e8
Middle 1 0004 000666e8
Right 1 0005 0006654f
Lowest 1 0005 0006654f
Z = -A1/(2*A2) : 002C
X = Z + Xavg : 0030
Curve 000c 00072513
New 0004 00066eab BER 00000003 AUTO
Servo Zone 00 OD OFST Lower f4d2 Upper f591 Step 0006 Right 1f Mask 00004340
Default f532 00023ad1 BER 00000059
Floor 1 1a 00052928 00052928
Left 1 f502 0004b41d
Middle 1 f534 00023730
Right 1 f567 00051e3f
Lowest 1 f532 00023730
X = Z + Xavg : 000F
Curve f52c 0002387b
New f534 000234f1 BER 0000004c AUTO
Servo Zone 01 OD OFST Lower f558 Upper f617 Step 0006 Right 1f Mask 00004340
Default f5b8 000209ff BER 00000039
Floor 1 18 00040f9e 00040f9e
Left 1 f58e 0003792e
Middle 1 f5ba 00020077
Right 1 f5e7 0003d9bd
Lowest 1 f5b8 00020077
X = Z + Xavg : 000F
Curve f5b2 000204de
New f5ba 00020133 BER 00000033 AUTO
Servo Zone 02 OD OFST Lower f5d5 Upper f694 Step 0006 Right 1f Mask 00004340
Default f635 0001f8d5 BER 00000038
Floor 1 19 00048775 00048775
Left 1 f605 000427c2
Middle 1 f634 0001eed6
Right 1 f664 0003bf49
Lowest 1 f62f 0001eed6
X = Z + Xavg : 000F
Curve f62f 0001eed6
New f634 0001fb96 BER 0000002d
Servo Zone 03 OD OFST Lower f654 Upper f713 Step 0006 Right 1f Mask 00004340
Default f6b4 0001f747 BER 00000032
Floor 1 17 0003f391 0003f391
Left 1 f68a 00034403
Middle 1 f6b6 0001e9d7
Right 1 f6e3 0003ede2
Lowest 1 f6b4 0001e9d7
X = Z + Xavg : 000F
Curve f6ae 0001ed47
New f6b6 0001f12e BER 0000001d AUTO
CUTOFF Lower 060f Upper 0615 Step 0001 Right 06 Mask 00000348
Default 0611 000663f8 BER 00000006
Floor 1 02 000674c7 000674c7
Left 1 0610 000667a9
Middle 1 0612 00067fd1
Right 1 0614 00066216
Lowest 1 0614 00066216
New 0612 00068683 BER 00000001
BOOST Lower 0012 Upper 0016 Step 0001 Right 04 Mask 00000360
Default 0014 00066a91 BER 00000002
Floor 1 05 0006a36c 0006a36c
Left 1 0014 00067ddb
Middle 1 0014 00067ddb
Right 1 0015 00068336
Lowest 1 0014 00067ddb
Not Enough Points to Curve Fit!
New 0014 0006709e BER 00000000
Default 0004 00066384 BER 00000007
Floor 1 0a 00066fb9 0006d6f2
Left 1 0004 00066fb9
Middle 1 0004 00066fb9
Right 1 0004 00066fb9
Lowest 1 0004 00066fb9
Z = -A1/(2*A2) : 001B
X = Z + Xavg : 001F
Curve 000c 00072de1
New 0004 00067503 BER 00000000
Rbck Noise OFF
Adjust ATTR 02 VGAS 89 VGAR 62 FREQR 80 within _ATT VGAR FREQR
MRASYM 4a 0001e7ab BER 00000030
MRASYM 48 0001ef96 BER 0000003d adapt
Test 00001dc7.00 0001c6df BER 00000023
MRASYM 4a 0001cd5f BER 0000001f
MRASYM 4c 0001cf8b BER 00000036 hold
NPML 03 0001cdd5 BER 0000002e NPML update
NPML 03 00035417 BER 0000000d
MRASYM 4a 00035331 BER 0000000e
MRASYM 51 0003560b BER 00000017 adapt
BETTER UPDATE TAPS Rbck DATA save
Media 0000
ASCII logging off
ASCII logging on
Adapt Servo Zone 09
Adapts Loaded
Rbck DATA load
NPML 00
Test 000173ac.00 00011814 BER 00000007
Adjust ATTR 02 VGAS 7a VGAR 64 FREQR 82 within _ATT
MRASYM 80 00014b14 BER 00000011
MRASYM 4e 000120f2 BER 00000008 update 4e hold
Test 000173ac.00 000116f1 BER 00000008
Test 00003b57.00 00035546 BER 00000010
RdBias Upper 0008 Lower 0001 Step 0001
SPT 0547 Revs 00b5
RdBias 08 VGAR 5d Rbt 09.0 OTF 09.0 Raw 05.7
RdBias 07 VGAR 64 Rbt 09.0 OTF 09.0 Raw 05.7
RdBias 06 VGAR 6d Rbt 09.0 OTF 09.0 Raw 05.6
RdBias 05 VGAR 78 Rbt 09.0 OTF 09.0 Raw 05.5
RdBias 04 VGAR 83 Rbt 09.0 OTF 09.0 Raw 05.4
RdBias 03 VGAR 91 Rbt 09.0 OTF 09.0 Raw 05.1
RdBias 02 VGAR a2 Rbt 09.0 OTF 09.0 Raw 04.8
RdBias 01 VGAR b7 Rbt 09.0 OTF 09.0 Raw 04.4
RdBias 06 VGAR 6e Rbt 09.0 OTF 09.0 Raw 05.6
Test 000173ac.00 0001263a BER 00000010
Adjust ATTR 02 VGAS 8c VGAR 78 FREQR 82 within _ATT
MRASYM 4e 00012d38 BER 0000000d
MRASYM 4b 0001304f BER 00000009 hold
XDCTAP 9c 00021f30 BER 00000000 adapt
XDCTAP 9c 00023055 BER 00000000 hold
PREAMP GAIN 02
Adjust ATTS 02 VGAS 8b VGAR 86 FREQR 7f VGAS_ADJUST 05 within _ATT
Default 007c 00022a67 BER 00000000
Floor 1 20 00027873 000317f8
Left 1 007a 0002399b
Middle 1 00ac 000237ed
Right 1 00df 00027873
Lowest 1 0092 0002212d
Z = -A1/(2*A2) : 0AAB
X = Z + Xavg : 0ABA
Curve 00d4 00026f09
New 00ac 00023b2c BER 00000000
000240fb BER 00000000 _ATT 02 VGAS 94 VGAR 7f FREQR 7e Taps frozen read adapt
Current Tap Weight 00004d8e diff ffffb272 tap limits
00023d19 BER 00000000 _ATT 02 VGAS 94 VGAR 7b FREQR 81 Taps frozen read adapt
Current Tap Weight 0000000a diff 00004d84 tap limits
00023dbe BER 00000000 _ATT 02 VGAS 93 VGAR 7e FREQR 81 Taps frozen read adapt
Current Tap Weight 0000001e diff ffffffec Save servo Force servo update
Test 000173ac.00 0001586c BER 00000fff
7
Media 0000
Channel Srvo Table
00 8766 7E 04 AC C6 6D 9A 8D 98 7C 9C 02
Performing Servo Cals, view results in log 3
ASCII logging off
CYL = 007C9 KA = 3F58 scaled by 4000 CYL = 017C9 KA = 3ED0 scaled by 4000
CYL = 027C9 KA = 3E50 scaled by 4000 CYL = 037C9 KA = 3E08 scaled by 4000
CYL = 047C9 KA = 3DD0 scaled by 4000 CYL = 057C9 KA = 3DA0 scaled by 4000
CYL = 067C9 KA = 3DA8 scaled by 4000 CYL = 077C9 KA = 3D78 scaled by 4000
CYL = 087C9 KA = 3DB0 scaled by 4000 CYL = 097C9 KA = 3D98 scaled by 4000
CYL = 10DBC KA = 3D58 scaled by 4000
CYL = 18329 KA = 3DA0 scaled by 4000 CYL = 19329 KA = 3D98 scaled by 4000
CYL = 1A329 KA = 3D98 scaled by 4000 CYL = 1B329 KA = 3DA8 scaled by 4000
CYL = 1C329 KA = 3DB0 scaled by 4000 CYL = 1D329 KA = 3DB0 scaled by 4000
CYL = 1E329 KA = 3DE0 scaled by 4000 CYL = 1F329 KA = 3E28 scaled by 4000
CYL = 20329 KA = 3EA0 scaled by 4000 CYL = 21329 KA = 3F60 scaled by 4000
Head Linearizing
Cyl = 010DBC
Head = 00 Gain Adjust = 0125
Head Linearizing
Cyl = 0002D4
Head = 00 Gain Adjust = 012B
Head Linearizing
Cyl = 0218A4
Head = 00 Gain Adjust = 0120
Table Linearization in Process
Head Gain Measure
Head Max -38h -28h -18h -08h +08h +18h +28h +38h
00 4DC1 3F67 40FC 447A 469F 4A3D 4DC1 4A76 43BE
Normalized Integrated Gain
Head -40h -30h -20h -10h 00 +10h +20h +30h +40h
00 0000 0342 0699 0A1E 0DC0 1191 1590 1964 1CE0
PES to Position Table
00 FFC0 FFCE FFDD FFED FFFD 000E 0020 0031 0040
ASCII logging on
Calibrating Physical Track 0 on heads 0 thru 0
Calibrating Head 0 ...
DAC value = FC83
Spin Ready
Head 0 Offset = 145D
Head 0 Offset = 0
Disk 40
RPO Calibration!
Head 0 Offset = 0
Head 1 Offset = DE50
Head 2 Offset = DE50
Head 3 Offset = DE50
Head 4 Offset = DE50
Head 5 Offset = DE50
ASCII logging off
ASCII logging on
Servo Zone 13, OD [000151D2.0,FBC1,01C1,C0]
Left Bath = FE6A, Right Bath = FF22 : Pick (FEC6) ( Min/Max AGC 91FE )
Servo Zone 14, OD [00016398.0,FC54,0254,C0]
Left Bath = FEFC, Right Bath = FFB2 : Pick (FF57) ( Min/Max AGC 89FA )
Servo Zone 15, OD [0001755E.0,FCF8,02F8,C0]
Left Bath = FF9D, Right Bath = 0053 : Pick (FFF8) ( Min/Max AGC 8CF7 )
Servo Zone 16, OD [00018724.0,FD95,0395,C0]
Left Bath = 0037, Right Bath = 00EE : Pick (0092) ( Min/Max AGC 89F5 )
Zone 9 - 1603e.0 Target = f (3)
0B 0C 0D 0E 0F 10 11 12 13 Loops Value
0000 0000 0017 02D0 02C5 0031 0000 0000 0000 0005 0003
Adapt Data Zone 09
Test 000173ac.00 WRITE FAILED
Test 000173cc.00 0000650e BER 00000000
Map 000173cc.00 Defects 0000
Test 000173cc.00 00006789 BER 00000002
Adapt Data 000173cc.00
Rbck DATA load
NPML 00
Test 000173cc.00 0000658b BER 00000001
Adjust ATTR 02 VGAS 89 VGAR 71 FREQR 81 within _ATT VGAR FREQR
MRASYM 80 00007b13 BER 00000000
MRASYM 46 0000697e BER 00000002 update 46 hold
Test 000163a0.00 00006580 BER 00000000
Servo Zone 14 OD OFST Lower fef7 Upper ffb6 Step 0006 Right 1f Mask 00004340
Default ff57 000065b0 BER 00000000
Floor 1 15 0000e9a2 0000e9a2
Left 1 ff33 0000bd35
Middle 1 ff5c 00006c19
Right 1 ff86 0000dd59
Lowest 1 ff5d 00006a42
X = Z + Xavg : 000F
Curve ff51 00006e86
New ff5c 00006b9a BER 00000001
Test 00017566.00 000066b9 BER 00000000
Servo Zone 15 OD OFST Lower ff98 Upper 0057 Step 0006 Right 1f Mask 00004340
Default fff8 00006681 BER 00000000
Floor 1 18 00013421 00013421
Left 1 ffce 0000efb2
Middle 1 fffd 00006983
Right 1 002d 00011ace
Lowest 1 fff8 00006983
X = Z + Xavg : 000F
Curve fff2 00006bf7
New fffd 00006986 BER 00000000
Adjust ATTR 02 VGAS 89 VGAR 6f FREQR 80 within _ATT VGAR FREQR
Test 000173cc.00 000065c0 BER 00000000
Rbck Noise OFF
Rbck DATA save
Test 000173cc.00 000063c4 BER 00000000
MRASYM 46 000065d9 BER 00000000
MRASYM 46 00006765 BER 00000000 hold
Default 0006 00006243 BER 00000000
Floor 1 0b 000055a7 000063ec
Left 1 0000 000055a7
Middle 1 0000 000055a7
Right 1 0001 000053fe
Lowest 1 0001 000053fe
Z = -A1/(2*A2) : FFFC
X = Z + Xavg : 0001
Curve 0001 000053fe
New 0000 0000565c BER 00000001
Test 000173cc.00 0000564b BER 00000000
XDCTAP 90 00005832 BER 00000000 adapt
XDCTAP 9a 000057f6 BER 00000000 hold
CUTOFF Lower 0417 Upper 043b Step 0002 Right 12 Mask 00000348
Default 0520 00047389 BER 00000000
Floor 1 0f 0004b082 0004d1cd
Left 1 0423 0004a351
Middle 1 042f 0004c2ad
Right 1 043b 0004a3c2
Lowest 1 0439 00049468
New 042f 0004c28b BER 00000000
Default 0014 00079b5e BER 00000000
Floor 1 17 000714f7 000a8695
Left 1 0016 000714f7
Middle 1 0016 000714f7
Right 1 0016 000714f7
Lowest 1 0016 000714f7
Z = -A1/(2*A2) : FFF3
X = Z + Xavg : FFFE
Curve 0015 00074ab2
New 0016 0004c880 BER 00000000 AUTO
Default 0006 0004c32f BER 00000000
Floor 1 0a 000460f6 00050df5
Left 1 0004 000460f6
Middle 1 0004 000460f6
Right 1 0004 000460f6
Lowest 1 0004 000460f6
Z = -A1/(2*A2) : 0004
X = Z + Xavg : 0008
Curve 000c 00052d1d
New 0004 000458d7 BER 00000000 AUTO
Servo Zone 14 OD OFST Lower fefc Upper ffbb Step 0006 Right 1f Mask 00004340
Default ff5c 0000789d BER 00000001
Floor 1 14 0000f69a 0000f69a
Left 1 ff32 0000ea18
Middle 1 ff58 00007ca9
Right 1 ff7f 0000ce2c
Lowest 1 ff5c 00007aef
X = Z + Xavg : 000F
Curve ff56 00007ca9
New ff58 000079f8 BER 00000000
Servo Zone 15 OD OFST Lower ff9d Upper 005c Step 0006 Right 1f Mask 00004340
Default fffd 000076c9 BER 00000000
Floor 1 17 000138db 000138db
Left 1 ffcd 000118b9
Middle 1 fff9 00007478
Right 1 0026 0000f078
Lowest 1 fff7 00007478
X = Z + Xavg : 000F
Curve fff7 00007478
New fff9 00007678 BER 00000002 AUTO
CUTOFF Lower 0423 Upper 043b Step 0001 Right 18 Mask 00000348
Default 042f 00045e7c BER 00000000
Floor 1 0e 0004570e 00046ab1
Left 1 0435 00045605
Middle 1 0438 00044d97
Right 1 043b 000449e3
Lowest 1 043a 00044790
New 0438 00045a6d BER 00000000 AUTO
BOOST Lower 0015 Upper 0016 Step 0001 Right 01 Mask 00000360
Default 0016 0004506e BER 00000000
Floor 1 02 0004466d 00044dde
Left 1 0015 0004466d
Middle 1 0015 0004466d
Right 1 0015 0004466d
Lowest 1 0015 0004466d
New 0015 00045605 BER 00000000
Default 0004 00044c42 BER 00000000
Floor 1 0a 0004527f 00051356
Left 1 0004 0004527f
Middle 1 0004 0004527f
Right 1 0004 0004527f
Lowest 1 0004 0004527f
Z = -A1/(2*A2) : 0006
X = Z + Xavg : 000A
Curve 000c 00056b63
New 0004 00045380 BER 00000000
Rbck Noise OFF
Adjust ATTR 02 VGAS 88 VGAR 70 FREQR 82 within _ATT VGAR FREQR
MRASYM 46 0000594c BER 00000002
MRASYM 45 000058ff BER 00000001 update 45 adapt
Test 000173cc.00 0000522c BER 00000003
MRASYM 45 00005378 BER 00000000
MRASYM 4a 000054b9 BER 00000001 hold
NPML 03 000055fa BER 00000001 NPML update
NPML 03 00017182 BER 00000000
MRASYM 45 00017278 BER 00000000
MRASYM 45 00016f90 BER 00000000 update 45 adapt
Media 0000
Zone 9 Hd 0 - Adaptives Reset After System Area Opti
Performing ACFC Cal
ASCII logging off
ACFC Calibration:
ASCII logging on
DC Erasing entire system area
Bst/Zap=0, SrvoThrsh=0, RunOut=0, MaxECC=0, ECC 2=0, ECC 1=0, ECC 0=1
Data=05, Write=40, ID=1E, DER=0000, RdWrOpts=0001
No entries in Log
ASCII logging off
EP=0, TA=0, HiGain=1, OTRd=0, Early Rd=0, Splash=1, Reload=1, NPML=1, MRBias=1
Data=0B, Write=40, ID=1E, DER=0009, RdWrOpts=27FF
