(图4)
其原因PDF为:ACDET: AC or adapter power detection. This input pin is used to determine the presence of the ac adapter.
When the voltage level on the ACDET pin is less than VACPRES, the bq24702/bq24703 is in sleep mode, the
PWM control is disabled, the BATDRV is driven low, and the ACDRV is driven high. This feature can be used to
automatically select battery as the system power source.
ACDRV: AC or adapter power source select output. This pin drives an external P-channel MOSFET used to
switch to the ac wall-adapter as the system power source. When the ACSEL pin is high while the voltage on the
ACDET pin is greater than VACPRES, the output ACDRV pin is driven low (VHSP). This pin is driven high (VCC)
when the ACDET is less than VACPRES.
ACPRES: This open-drain output pin is used to indicate the presence of ac power. A logic high indicates there is
a valid ac input. A low indicates the loss of ac power. ACPRES is high when the voltage level on the ACDET pin
is greater than VACPRES.
简单翻译后的中文为:ACDET:AC或适配器电源检测。这个输入引脚用于确定AC适配器。
当上ACDET引脚的电压水平比VACPRES少,bq24702/bq24703是在睡眠模式下,
PWM控制被禁用,BATDRV驱动低,ACDRV驱动高。此功能可用于
自动选择电池作为系统电源。
ACN, ACP: Negative and positive differential inputs, respectively for ac-to-dc adapter current sense resistor.
ACSEL: AC adapter power select. This input selects either the ac adapter or the battery as the power source. A
logic high selects ac power, while a logic low selects the battery.
ACSET: Adapter current programming voltage. This input sets the system current level at which dynamic power
management occurs. Adapter currents above this programmed level activate the dynamic power management
and proportionally reduce the available power to the battery.
ALARM: Depleted battery alarm output. This open-drain pin indicates that a depleted battery condition exists. A
pullup on ALARM goes high when the voltage on the BATDEP pin is below VACPRES. On the bq24702, the
ALARM output also activates when the selector inputs do not match the selector state.
BATDEP: Depleted battery level. A voltage divider network from the battery to BATDEP pin is used to set the
battery voltage level at which depletion is indicated by the ALARM pin. See ALARM pin for more details. A
battery depletion is detected when BATDEP is less than VACPRES. A no-battery condition is detected when the
battery voltage is < 80% of the depleted threshold. In a no-battery condition, the bq24702 automatically selects
ac as the input source. If ENABLE = 1, the PWM remains enabled.
BATDRV: Battery power source select output. This pin drives an external P-channel MOSFET used to switch the
battery as the system's power source. When the voltage level on the ACDET pin is less than VACPRES, the output
of the BATDRV pin is driven low, GND. This pin is driven high (VCC) when ACSEL is high and ACDET > VACPRES.
BATP: Battery charge regulation voltage measurement input to the battery-voltage gm amplifier. The voltage on
this pin is typically derived from a voltage divider network connected across the battery. In a voltage loop, BATP
is regulated to the VFB precision reference of the battery voltage gm amplifier.
BATSET: An external override to an internal precision reference. When BATSET is > 0.25 V, the voltage level on
the BATSET pin sets the voltage charge level. When BATSET ≤ 0.25 V, an internal VFB reference is connected
to the inverting input of the battery error amplifier. To ensure proper battery voltage regulation with BATSET,
BATSET must be > 1.0 V. Simply ground BATSET to use the internal reference.
COMP: The inverting input to the PWM comparator and output of the gm amplifiers. A type II compensation
network between COMP and GND is recommended.
ENABLE: Charge enable. A high on this input pin allows PWM control operation to enable charging while a low
on this pin disables and forces the PWM output to a high state. Battery charging is initiated by asserting a logic 1
on the ENABLE pin.
GND: Supply return and ground reference
IBAT: Battery current differential amplifier output. The output of this pin produces a voltage proportional to the
battery charge current. This voltage is suitable for driving an ADC input.
PWM: Gate drive output pin drives the P-channel MOSFET for PWM control. The PWM control is active when
ACPRES, ACSEL, and ENABLE are high. PWM is driven low to VHSP and high to VCC.
SRN, SRP: Differential amplifier inputs for battery current sense. These pins feed back the battery charge current
for PWM control. SRN is tied to the battery terminal. SRP is the source pin for zero volt operation.
SRSET: Battery charge current programmed voltage. The level on this pin sets the battery charge current limit.
VCC: Operational supply voltage.
VHSP: The VHSP pin is connected to a 1-μF capacitor (close to the pin) to provide a stable voltage source to
drive the gates of the external MOSFETs. VHSP = VCC – 10 V for VCC > 10.5 V and VHSP = VCC – 0.5 V for
VCC <10.5 V. A 13-V Zener diode should be placed between VCC and VHSP to prevent MOSFET overstress
during start-up.
VREF: Bypassed precision voltage 5-V output. It can be used to set fixed levels on the inverting inputs of any
one of the three error amplifiers if desired. The tight tolerance is suitable for charging lithium-ion batteries.
VS: System (Load) voltage input pin. The voltage on this pin indicates the system voltage in order to insure a
break before make transition when changing from ac power to battery power. The battery is protected from an
over-voltage condition by disabling the P-channel MOSFET connected to the BATDRV pin if the voltage at VS is
greater than BATP. This function can be eliminated by grounding the VS pin.
