标题: 报2010arning这个错大家是如何解决的?? [打印本页] 作者: 唔卡卡 时间: 2009-11-2 13:42 标题: 报2010arning这个错大家是如何解决的?? ERROR
2010arning:your internal hard disk drive(HDD) may not fuction correctly on this system.Ensure that your HDD is supported on this system and that the latest HDD firmware is installed
Press ESC to continue
