标题: 两张9550 R3检测结果,那颗显存坏? [打印本页] 作者: 庞福元 时间: 2009-10-8 04:44 标题: 两张9550 R3检测结果,那颗显存坏? 两张9550 R3检测结果,那颗显存坏?
第一张:两128的9550显卡 R3检测结果如下:
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
RV350/M10 (0x4150) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : FAIL
Error ID G0VB001
1024 x 768 - 16 bpp ( 60 Hz): TEST FAILURE
failing bit : MDA0 34 MDB0 33 35 52 54
[2 ] Data line toggle (GUI) : FAIL
Error ID G0VB023
failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[11 ] Marco+Micro8x2 alignment write : PASS
[12 ] Macro+Micro4x4 alignment read : PASS
[13 ] Movblit, 4 align, T : FAIL
Error ID G0TR055
1024 x 768 - 16 bpp ( 75 Hz): TEST FAILURE
error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L : FAIL
Error ID G0TR014
640 x 480 - 8 bpp ( 75 Hz): TEST FAILURE
error : R051A.14 not found
640 x 480 - 15 bpp ( 75 Hz): TEST FAILURE
error : R052A.14 not found
640 x 480 - 16 bpp ( 75 Hz): TEST FAILURE
error : R053A.14 not found
640 x 480 - 32 bpp ( 75 Hz): TEST FAILURE
error : R055A.14 not found
800 x 600 - 8 bpp ( 75 Hz): TEST FAILURE
error : R061A.14 not found
800 x 600 - 15 bpp ( 75 Hz): TEST FAILURE
error : R062A.14 not found
800 x 600 - 16 bpp ( 75 Hz): TEST FAILURE
error : R063A.14 not found
800 x 600 - 32 bpp ( 75 Hz): TEST FAILURE
error : R065A.14 not found
1024 x 768 - 8 bpp ( 75 Hz): TEST FAILURE
error : R071A.14 not found
1024 x 768 - 15 bpp ( 75 Hz): TEST FAILURE
error : R072A.14 not found
error : R073A.14 not found
1024 x 768 - 32 bpp ( 75 Hz): TEST FAILURE
error : R075A.14 not found
[15 ] Line slopes/dir/P/solid : FAIL
Error ID G0TR010
error : R051A.15 not found
error : R052A.15 not found
error : R053A.15 not found
error : R055A.15 not found
error : R061A.15 not found
error : R062A.15 not found
error : R063A.15 not found
error : R065A.15 not found
error : R071A.15 not found
error : R072A.15 not found
error : R073A.15 not found
1024 x 768 - 32 bpp ( 75 Hz): TEST PASSED
Failure detected.
第二张:128bit 256M 9550
RV350/M10 (0x4153) detected.
256M video memory.
[1 ] Fill : FAIL
Error ID G0VB001
1280 x 1024 - 16 bpp ( 60 Hz): TEST FAILURE
failing bit : MDA0 2 34 MDB0 32 33 50 51 52 53 54 55 ...
[2 ] Data line toggle (GUI) : PASS
[3 ] RW column (GUI) : FAIL
Error ID G0VB024
Error ID G0TR055
Error ID G0TR014
Error ID G0TR010
Failure detected.作者: 多多 时间: 2009-10-9 12:39
背面下数第一颗作者: 庞福元 时间: 2009-10-10 01:09
谢谢一会试一下看看。作者: 庞福元 时间: 2009-10-11 02:04
两张显卡均修好了。第一块坏了背面上往下数第一颗 第二张是背面上往下数第一颗和第二颗。谢谢新诚达作者: 镇三山 时间: 2009-10-11 10:05
两个区同时坏的基本都是GPU坏了作者: 姜洋吧外交 时间: 2009-11-23 13:58
提示: 作者被禁止或删除 内容自动屏蔽作者: 希望的寄托 时间: 2009-11-26 13:36
反面下数第一颗 第二颗 反面上边左边一颗作者: 电猫 时间: 2010-1-5 16:59
A面下数第一颗和B面下数第一颗!作者: 谢龙飞 时间: 2010-1-5 17:12
B的是在背面上面右边那个.
