DELL 640M报ERROR CODE 0221
季慧飞
2009-9-4 09:23
我昨天收到一台DELL 640M,进不了系统,能进DOS。用PE光盘也无法启动。进dell自检程序,报ERROR 0221,请教各位大哥,这一般是什么问题?不甚感激!!!!!!!!!!!!
唐某
2009-9-4 09:27
刷一下BIOS试一下
季慧飞
2009-9-4 09:34
已刷到了最新的BIOS了
尽我所能
2009-9-4 09:36
重新插拔下BIOS电池试试。
季慧飞
2009-9-4 10:03
电池拆掉也一样
重剑无锋
2009-9-4 10:07
这是什么错误
东海之鲲
2009-9-4 10:07
dell 自检程序怎么说的?
孟德勇
2009-9-4 10:08
这个我也没有遇到过,期待学习。。。。
板修不好
2009-9-4 10:10
最好发过图上来看一下。
季慧飞
2009-9-4 10:10
DELL:“according to dell site the code means Interval Timer Channel 0 (mode 0) is not generating interrupts. ”
东海之鲲
2009-9-4 10:28
诊断卡用了吗
小小工作室
2009-9-4 10:32
期待高手给予解答
金少波
2009-9-4 10:37
dell要看灯是怎没闪烁的,
老张小张
2009-9-4 10:37
error 0221: chipset interval timer failed ater redoing the diagnostics
季慧飞
2009-9-4 12:15
灯的显示全部正常。只是进系统时就死机
季慧飞
2009-9-8 10:41
没人遇到这故障吧吗?
李怀利
2009-9-8 10:59
Step 1: Start the PSA Diagnostics
Restart the system.
At the Dell logo screen, press <F12>.
At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics, then press <Enter> to begin PSA.
Write down any error codes listed.
Use the list provided in the next section to see what the error code means.
Back to Top
Step 2: Error Code List
If you recieve an error during PSA Diagnostics, look below for the associating error code.
Error Code
Error Message
PSA 1000-0111
PSA+ 2000-0111
(Name of Exception) exception occurred at selector XXh offset XXh.
PSA+ 2000-0112
CPU (x): Processor machine check exception error.
PSA+ 2000-0113
Processor machine check error detected.
PSA 1000-0122
Memory test initialization failure.
PSA 1000-0123
PSA+ 2000-0123
Memory integrity test failed.
PSA 1000-0141
PSA+ 2000-0141
No drive detected.
PSA 1000-0142
PSA+ 2000-0142
Drive Self Test failed. Status byte = XXh.
PSA 1000-0143
PSA+ 2000-0143
Drive Smart read command failed.
PSA 1000-0144
PSA+ 2000-0144
No support for Drive Self Test.
PSA 1000-0145
PSA+ 2000-0145
Timeout waiting for Drive Self Test to complete.
PSA 1000-0146
PSA+ 2000-0146
DST Log contains previous error(s).
PSA 1000-0147
PSA+ 2000-0147
Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s).
Unit (d): Optical drive BIST – (s).
PSA 1000-0148
PSA+ 2000-0148
IDE ERROR: status (x) (s)
PSA+ 2000-0149
No optical drive detected
PSA 1000-0212
PSA+ 2000-0212
CMOS failed the pattern test.
PSA 1000-0213
PSA+ 2000-0213
The CMOS battery failed
PSA 1000-0214
Failure in DMA %s Port: XXh.
PSA 1000-0221
PSA+ 2000-0221
PSA 1000-0222
Interval Timer Channel 0 (mode 3) is generating the wrong interrupt count per second.
Error Code
Error Message
PSA 1000-0223
Interval Timer initial clock output level in mode XX is incorrect.
PSA 1000-0224
Interval Timer had wrong time period in mode XX
PSA 1000-0231
PSA+ 2000-0231
Failure in Interval Timer in mode XX.
PSA 1000-0232
PSA+ 2000-0232
The RTC did not generate periodic ticks.
PSA 1000-0233
PSA+ 2000-0233
The RTC 'Seconds' register is not updating.
PSA 1000-0234
PSA+ 2000-0234
Timeout waiting for RTC update flag to set.
PSA 1000-0235
PM timer 1 had wrong time period. Expected (d), Actual (d).
PSA 1000-0241
PSA+ 2000-0241
Error enabling A20 gate.
PSA 1000-0242
PSA+ 2000-0242
No interrupt detected for IRQ XX - (Name of Interrupt).
PSA 1000-0312
Keyboard test timed out waiting for keyboard response.
PSA+ 2000-0313
Error detecting internal touchpad or pointing stick.
PSA 1000-0321
PSA+ 2000-0321
Unable to detect LCD.
PSA 1000-0322
PSA+ 2000-0322
Error accessing the LCD inverter.
PSA 1000-0326
PSA+ 2000-0326
LCD inverter error, unable to turn lamp ON/OFF.
PSA+ 1000-0331
No video adapter found.
PSA 1000-0332
Video memory failed.
PSA 1000-0333
PSA+ 2000-0333
Graphics test timed out waiting for keyboard response.
PSA 1000-0334
PSA+ 2000-0334
User reported that graphics patterns were not displayed correctly.
PSA+ 1000-0411
Hardware Detect Error - (s) not detected.
Error Code
Error Message
PSA+ 1000-0412
Hardware Detect Error - Auxiliary LCD cable not detected.
PSA+ 1000-0413
Detect Error - LCD cable not detected.
PSA+ 1000-0414
Hardware Detect Error - Inverter cable not detected.
PSA+ 2000-0151
PSA+ 2000-0152
Optical Drive (d): - Incorrect status: (x) (s)
Back to Top
Step 3: What to do if you recieved an Error code
Contact Dell Technical Support.
Click Here to Contact Technical Supp
季慧飞
2009-9-15 16:31
换主板,好了
