Ñ¸Î¬Íø
±êÌâ: M.2 PCIE 3.0 Mai Guang 1TB ¹Ì̬ӲÅÌ£¬ Ö÷¿ØÊÇ SM 2263XT [´òÓ¡±¾Ò³]
×÷Õß: bfire    ʱ¼ä: 2026-9-9 09:09
M.2  PCIE 3.0   Mai Guang  1TB ¹Ì̬ӲÅÌ£¬ Ö÷¿ØÊÇ SM 2263XT£¬
¶Á³öµÄ bank00 ÏÔʾÊÇ  º£Á¦Ê¿µÄ falsh ¿ÅÁ£Â𣿠flash ID ÊÇ0xad,0x7e,0x29,0xb £¿£¿
FLASH ID ¹¤¾ß¶Á³öµÄÐÅÏ¢£º
v0.275a
OS: 10.0 build 19045
Drive     : 1(NVME)
Scsi      : 1
Driver    : W10
Model     : MG M.2 NVMe SSD 1TB
Fw        : V0808A0
HMB       : 32768 - 65536 KB (Enabled, 64 M)
Size      : 976762 MB [1024.2 GB]
LBA Size  : 512
AdminCmd  : 0x00 0x01 0x02 0x04 0x05 0x06 0x08 0x09 0x0A 0x0C 0x10 0x11 0x14 0x80 0x81 0x82 0xC0 0xC1 0xC2
I/O Cmd   : 0x00 0x01 0x02 0x05 0x09
Controller:  [SM2263XT] bufferless
Bank00: 0xad,0x7e,0x29,0xb,0x0,0xc0,0x0,0x0 - Hynix 3dv7-176L TLC 16k 1024Gb/CE 512Gb/die
Bank01: 0xad,0x7e,0x29,0xb,0x0,0xc0,0x0,0x0 - Hynix 3dv7-176L TLC 16k 1024Gb/CE 512Gb/die
Bank02: 0xad,0x7e,0x29,0xb,0x0,0xc0,0x0,0x0 - Hynix 3dv7-176L TLC 16k 1024Gb/CE 512Gb/die
Bank03: 0xad,0x7e,0x29,0xb,0x0,0xc0,0x0,0x0 - Hynix 3dv7-176L TLC 16k 1024Gb/CE 512Gb/die
Bank08: 0xad,0x7e,0x29,0xb,0x0,0xc0,0x0,0x0 - Hynix 3dv7-176L TLC 16k 1024Gb/CE 512Gb/die
Bank09: 0xad,0x7e,0x29,0xb,0x0,0xc0,0x0,0x0 - Hynix 3dv7-176L TLC 16k 1024Gb/CE 512Gb/die
Bank10: 0xad,0x7e,0x29,0xb,0x0,0xc0,0x0,0x0 - Hynix 3dv7-176L TLC 16k 1024Gb/CE 512Gb/die
Bank11: 0xad,0x7e,0x29,0xb,0x0,0xc0,0x0,0x0 - Hynix 3dv7-176L TLC 16k 1024Gb/CE 512Gb/die
Channel: 4
CE     : 2
Plane  : 4
Die/Ce : 2
Ch map : 0x0F
CE map : 0x05
Bit Per Cell  : (TLC)
Inter.        : 4
Pages/Block   : 4224(960)
First Fblock  :    1
Total Fblock  :  271
Total Hblock  : 7631
Fblock Per Ce :  271
Fblock Per Die:  271
Original Spare Block Count :    10
Vendor Marked Bad Block    :     0
Bad Block From Pretest     :     4
SM2263XT Telemetry data:
VERSION                                                  :                1
Re-allocated Sector Count (TLC/MLC)                      :                7
Power-on Hours Count                                     :            10120
Temperature                                              :               52
RE-allocated Sector Events                               :        168144527
Total LBAs Written                                       :      39852719681 [19003GB]
Total LBAs Read                                          :      86520044205 [41256GB]
SLC Available Spare Blocks (SLC)                         :               10
SLC NAND Writes (SLC)                                    :      49852379136
TLC NAND writes (TLC/MLC)                                :      72677870704
Current SLC spare super block (SLC)                      :                5
TLC Erase cycle average                                  :              166
TLC Erase cycle Max                                      :             2999
TLC Erase cycle Min                                      :                5
E2E detect count                                         :              229
Throttling light count(transit to PS1 from PS0 and PS2)  :             1024
Throttling heavy count(transit to PS2 from PS1)          :               26
Retry count (retry trig)                                 :        168144527
total manufacture bad count(unit : plane)                :                2
Worst manufacture bad count(unit : plane)                :              107
SLC Valid 4K count                                       :                5
TLC Valid 4K count                                       :                2
SLC system block writes(sector)                          :                3
SLC writes due to read disturb(sector)                   :                7
×÷Õß: bfire    ʱ¼ä: 2026-9-9 09:47
ÔÚÁ¿²ú²¿ÂäÒѾ­ÕÒµ½¶ÔÓ¦µÄ¿ª¿¨¹¤¾ß£¬ Âó¹â Ì«²»ÀÏʵÁË£¬ ʹÓú£Á¦Ê¿µÄ flash ¿ÅÁ££¬ ¾ÓÈ» ÖØÐ ´ò±ê¡£¡£
×÷Õß: u1504154    ʱ¼ä: 2026-9-9 10:29
¸Ðл·ÖÏí³É¹¦¾­Ñé°¡¡£
»¶Ó­¹âÁÙ Ñ¸Î¬Íø (https://www.chinafix.com/) Powered by Discuz! X3.4
