标题: SUNNY Android TV [打印本页]
作者: asliyucegsm    时间: 2026-9-8 02:02
my friend
SUNNY Android TV
SUNNY SN49DAL27\0216
TRSNDLD049250100011962
No picture; the backlight LEDs are on, and the standby light is flashing.
I need the firmware and software for the eMMC, information on which program/tool ?to use to flash the eMMC, and a connection diagram.
How do I connect and perform an upgrade on this setup using an RT809H or eMMC?
thanks
作者: VXiTVREc    时间: 2026-9-8 09:11
那不是电阻,是颗电容。
作者: now12345    时间: 2026-9-9 12:01
直接换板七八百,NO thanks
作者: asliyucegsm    时间: 2026-9-10 00:43
Mate, these devices can be brought back to life by flashing software; I need the pinout diagrams for the RT809H to program the eMMC chip—whether via USB or through the programmer's ports.
